10 members (Bill Hanlon, pdlightning, 1955 1 Series, dt235sd, mo2cyl, FAST55, Steelonsteel, MikeE, sron48, klhansen),
75
3
Mod | | | Forums66 Topics128,050 Posts1,055,667 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | I'm trying to get my original horn working so I'm trying to figure a way to test the relay. Please correct me if I'm wrong. On my horn relay there are 3 connections, power coming in, a lead to the horn and the third lead to the horn button. The relay functions and the horn blows when the lead to the horn button is connected to ground. Is this right?
If this is correct then when I jump the terminal that goes to horn button directly to ground it should work if the relay is functioning correctly and of course the other connections are in the right spot. Is this correct? Does this make sense? | | |
