Almost all of the GM 3/4-ton trucks old and new use the same U-joint, any parts man that knows his stuff can pick one off the shelf with no trouble at all.
This is just true only for the rear and center U-joint, the front one is a bit more difficult to find and you may have to put a “want ad” in a few forums to find one.
Denny Graham
Sandwich, IL
i guess auto parts men that know there stuff are in short supply in my neighborhood. i'll cast a wider net and see if i'm met with something other then a blank stare.
i recently purchace my bolt and the few times i've gone shopping for parts there have been problems. eventualy i'll find a store that is fammiliar with the older stuff.
thanks again.
