| | | Forums66 Topics128,151 Posts1,057,009 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 12 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 12 | The '57 3200 I am restoring has the 1955-6 steering wheel- flat across, not the "deep dish" type noted as used on the '57s. Is it possible that they used up some of the '56 steering wheels in 1957 production before they switched to the new wheel? The truck has a '57 VIN code and a '57 grille so I am pretty sure it's a '57. Also the steering column is shorter with a '57 steering wheel, to account for the wheel deep dish, right? I actually prefer the '56 wheel's appearance and do not want to change out the steering column but will if it is not correct for the restoration. Can any fellow 'Bolters shed light on this?
The very best nugget of wisdom anyone could ever offer you in dealing with your wife: You can be happy, OR, you can be right.
