Someone else must have run into this problem and came up with a created fix. I bought a a window channel kit from The Filling Station. Old parts removal went great until it came to the small rubber scrapers. It says that the pieces must be slid into metal retainer channel. HOW DO YOU CLEAN THE CHANNEL. The top part was ok but I can not get to the groove on the bottom. Is there a special tool that I need? If I have to use heat how much before I blister the paint. Have spent two days on this and I don't want to skip over it.
Old guy is getting very fustrzted.
Thank you.
