So I got some other questions about some glove box codes in the donor truck... Mainly I'm trying to figure out what tranny is in the donor cuz it has a 5 speed "spicer I think" but not sure which ratios it has cuz I'd love to have it if it has the highway .80:1 ratio in fifth.... But there are other spicers that just have 1:1 ratio and my fourth gear is that so it wouldn't make it worth grabbing.
any glovebox codes decoders out there? The code that has to do with the trany is "sp3152F" the option number is "M78LB"...
And the other thing I'm gonna get is the hydraulic steering cylinder, lines, assisted steering knuckle, and already have a power steering gearbox from another c50 truck with the resivoir attached. So eventually when I get it all installed I'll be driving 5-8mph faster top end speed, I'll be able to back a trailer up without the workout, and I think this rear has wider brakes so maybe even stop better two!!!
