Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (ShopRag, 1 invisible), 145 guests, and 3 robots.
Topics128,283
Posts1,058,506
Members48,490
Page 87 of 177 1 2 … 85 86 87 88 89 … 176 177
Finished the door glass installation on the 1953. Leveled out the cab & rear bumper. Rechecked all the nuts & bolts on the frame & under bed & cab. taking to bodyshop this week to get the final cut & buff done.
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
Corrected the steering linkage on the '59. Now it turns freely.
Blead the new brake system (4 wheel power disc) on the '59.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
For my '59, I transferred a good bench seat bottom set of springs to a good metal base, replaced any spring coils that were broken and sprayed the set flat black.
I replaced broken springs from the seat back and painted it as well.
I got the tracks lubed up and working perfectly.
Now, I've ordered an upholstry kit and I'm anxiously waiting to get it all together!
Guess it was technically last night but...
Drove my truck for the first time since ive owned it under its own momentum!!!
No brakes hooked up yet, just ran it in granny low around the shop about .1 miles but boy was that a rewarding feeling!
Couple cooling bugs to fix and then the brakes, the end is in sight!
Chooglin
1954 3600
[/url] www.tors54.tumblr.com
Winter project was installing power steering in a 55 2nd. Two years ago when I restored the truck, I made the mistake of using over size tires and wheels. Now with a late GM pump and a Toyota box, life is good.
dry fitting the body wood for my 35 high cab and some dent work on cab , leading
Not a darn thing, My truck in in Mi. and I am in Fl. I'll get started in 2 weeks. Making my shift lever long enough so I can reach 4th gear without un-buckling my seat belt Then I will refinish the Bed so I wont get slivers in my hand when I try and wax it.
I got the old bed off! I was a little excited in this video because just me and a buddy lifted it off, stood it up and let it slam down by ourselves. It was funny, we stood it up on it's end then looked at each other and we both said, "now what"? lol
Just one more step......
http://www.flickr.com/photos/ajporsche/8548076581/in/set-72157632234070092
Looking good Dawg!
~Jim
Waiting on wheels...then off to install the new MII clip. Should ride a lot better and be safer around this hilly town. Really looking fwd to power brakes with a new MC.
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
put some body filler where the anntena hole was welded closed
Well I took a bunch of photos of the 1953 truck. Loaded the truck on trailer & took it to the bodyshop to get the hood repainted & buffed.
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
The previous owner of my truck was unsucessful getting the turn signals to work. Opened up the sixty year old turn signal switch and gave it a good cleaning, ohmed out all the contacts and found one that needed resoldering. Then lubed it up with some dielectric grease put it all back together, then wired it up correctly,seems old owner had a single element front parking lights that he thought he could do turn signals and park lights at the same time (oh brother). Flasher was burned out and installed a fuse to protect things too. Got that all working great. Next thing I did was installed the new voltage regulator so the generator can charge the battery. You know 6 volt systems get a bad wrap, how folks think you can get it to crank with the little battery wires that you buy at the discount parts house is beyond me. Simple rule of thumb, if you have 1/2 the voltage then you need twice as much amperage, thus the need for some nice single ought wire and ground too. funny how you get the right parts , how well it works. Next I tackle the vacuum wiper motor. My plan is to get the truck so I can every day drive it reliable before planning a restore.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Good plan. Get a feel for it before you decide what needs to be changed.
Washed it , ready for the hotrod BBQ tonight. smile
Installed the used spindle on the 37 and seems to tight so I will finish up the installation tomorrow night.
SSTOCK, Nice truck. I really like that yellow. Thinking my next truck I'll paint yellow/white two tone or a blue/white two tone. Where in Washingon are ou locatated? Laters
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
Sandblasted more intake parts. Cleaned the throttle body. Tested an electric fan I might use. Started sorting out the VSS issue.
More pictures added. http://www.bunchobikes.com/1952suburban6.htm
Finished the spindle installation and will test drive tonight.
finished making the left lower cowl patch on the 35 high cab, now on to the right then blast it and lead, another week or so should do it, unless I move to one of the many other things that need my help,
I got the frame painted om the 46 today.now I can get the engine and driveline back in it
Made a patch panel and got it installed it on the rear part of the roof that bolts to the side wall of the panel. Painted the rails that bolt the roof together with Zero Rust. Hope to start getting the roof back on tomorrow.
1937 Chevy 1/2 ton panel
Decided to just make some panels and cover them with fabric for the sides of my panel. Six individual panels. Got them in but need just a bit of tweeking. Not professional but I think its good to go. I'll post some pics maybe tomorrow when I can get some time.
Made a few walk around videos of the truck, with the help of my wife...
I've been adjusting the Edelbrock carb on the new engine.It has a bog whenever you go hard throttle at any speed.Took it for a road test today.It seems I'm going the right direction.I stomped on it at idle speed.It still bogged but not as bad,but seemed to accelerate slowly.I realized the back tires were spinning.The old engine never did that!
Blasted and powder coated the first of five wheels. Went a little crazy with the color but I think it'll look cool with a ribbed trim ring and correct AD Chevy cap. ...besides, at $8-10 for a pound of powder, I can always redo em. cool
http://farm9.staticflickr.com/8379/8568129377_754c493f91_b.jpg
...that one is the spare and as such was our practice run. The other four should come out a tad smoother.
Add a 1/2" to 1" spacer under the carb and the problem will go away.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I drug the engine and tranny out of the corner last night, cleaned them up and going to give them a fresh coat of paint tonight.I may need some help when I put engine back in.I can't remember how the rear motor mounts work.
back yard wrench turner
Took it be to filmed in a movie.
Movie Day
Full Sail University students filming their final project (thesis) before graduation asked me if they could film my truck in their movie.
I spent most of the day with them. Had a fun time watching how a movie is made.
These students will be the future movie makers.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Wayne -
That's great. Vern's gonna be wearing shades and dating young Chevys wearing "hussie-red" paint! You and beast54 are in the big time.
- Lonnie
My '54 3104
Cut out the diamond plate that farmer Brown had welded to the entire top of this '53 factory flatbed. With the help of a good friend we used an abrasive wheel in a skil saw plus an angle grinder, attempting to cut just at the original factory edge so I can return this to stock. The boards and runners are pretty good only may need to replace one broken board ane may flip them over. If there are any original 3600 series flatbeds out there I'd like to see one to compare. Believe these were painted black from the factory, at least I think I can see some black stain or paint in some places.
1946 1/2-Ton Chevy
Well, I got the 3.38 center section back in the panel and slide the axles in. Called it a day. Hopefully tomorrow put the drums and wheels back on and go for a ride...at least by Saturday.
...oh, and don't forget to put grease in it smile lol
and go for a ride...at least by Saturday. smile lol
Make that ride to Florida and our Gabfest! smile
Wayne
1989 Silverado
Finally cut the junk off the back of my frame.
Before...
After...
Unfortunately, it looks like wen he p/o broke some springs on the RR driver side, the frame bottomed out on the axle and tweeked it some...
4 bolts to remove rear axle and I have a stripped frame!
Anyone have any pics of the rear portion of a 3800 or 4100 frame? I'm wondering what the shape of a small cross member is supposed to be and also if the c-channel is capped at the end of the frame.
Tj
Tj
Frame ends are not capped, but can be done. I'll take a few pictures of mine & send them to you.
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
Thanks!
I think the previous owner cut my frame ends at an angle and capped them.
I also found a pick of someone that says they have a 3800 but there are about 1/5 foot frame extensions on the back. I didn't think the 3800 had extensions...
looking forward to the pics!
Tj
I cleaned ,sand blasted the manifolds.also put a coat of high heat paint on them
Rewired my truck ('52) only took about four hours. Its was the $150 from classic. It went in fast and easy. No more sparks and light show at night.
1952 Chevy 3/4 ton
1948 Simplex Motorcycle
1930 Ford Model A Coupe
1928 Ford Model A Station Wagon
I removed the master cylinder for replacement and realized the lady at FLAPS had given me one for a AD truck instead of my TF. So now I have to wait until tomorrow for the correct master cylinder, which is still WAY better than ordering online and waiting several days for delivery. I have been fortunate to have such a great parts store nearby that is owned by a very knowledgeable brother/sister team that rarely makes mistakes like this.
http://s1341.photobucket.com/user/oldbolter/library/?page=1
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
