BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
5 members (VEW, GMCJammer51, 3 invisible),
571
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Apr 2019 Posts: 116 'Bolter | 'Bolter Joined: Apr 2019 Posts: 116 | Anyone near SE PA have a 16"x4.5" rim in decent shape for sale? I need to have a spare tire for the truck. Thanks, JD
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear) | | | | Joined: Sep 2009 Posts: 4,392 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 4,392 | JD1 - Can we surmise that this is for your 1951? How near is "near"??? I'll see what I can find a bit later as I get a chance to do some web sleuthing.  Best of luck!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | Joined: Apr 2019 Posts: 116 'Bolter | 'Bolter Joined: Apr 2019 Posts: 116 | Thanks Dan. The spare would be for my 1951 3100.
I was hoping to find something local. Not sure how much it would be to ship a rim, but I can do that if it's not too bad.
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear) | | | | Joined: Aug 2018 Posts: 729 'Bolter | 'Bolter Joined: Aug 2018 Posts: 729 | I shipped one not too long ago. I think it was around $30 via Fed X ground
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | Joined: Apr 2019 Posts: 116 'Bolter | 'Bolter Joined: Apr 2019 Posts: 116 | Thanks guys. That sounds more reasonable than I thought.
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear) | | | | Joined: May 2015 Posts: 9,830 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 9,830 | I shipped a 55.2 wheel (5" wide) from SoCal to NorCal back in Feb by USPS - Cost was $21. It would have been $40 if I shipped it from Alaska.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | Joined: Dec 2020 Posts: 209 'Bolter | 'Bolter Joined: Dec 2020 Posts: 209 | I have a full set of wheels I took off my ‘50, and one of them even has a zero mile spare mounted. I’m away from home till the middle of next week and can check widths of the wheels. | | |
