Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
11 members (bucktruck, 2ManyTrucks, fonz8261, Peggy M, wilbur53, Gib70, greenie-reddy, 1942-G506, Lightholder's Dad, 2-Ton, Otto Skorzeny), 586 guests, and 1 robot.
Topics126,776
Posts1,039,258
Members48,100
Most Online2,175
Jul 21st, 2025
#1587541 09/16/2025 6:18 PM
I'm planning on doing a chassis swap on my 1941 GMC 1/2 ton pickup truck, using the chassis from a 2003 Chevy S10 Extended Cab pickup truck. The body was very rusty but the chassis is in good shape and the truck is mechanically in good shape with fairly low miles. This project may go in bursts so there could be periods of inactivity on this post. I'm excited about it and would love to work on it non-stop but I have other commitments.
Started with the 2003 S10. Normally I would remove the bolts from underneath but they were rusted on so bad I couldn't get them off. I didn't want to torch them with a fuel tank nearby so I tore off the box and cut off the bolts from the top after the box was off making them easily accessible. I used a reciprocating saw similar to a Sawzall, with a fire rescue blade from Menards, to cut the cab apart.
Save all you can from the donor, I used the s10 steering coloumn and it works great and then you can get a painless harness to match right up to it, piece of cake for signals and wipers and dimmer ignition maybe others I put electric wipers in mine, I can get you the name of the place I got them from if you want. I am putting electric windows in my coe also, can get you that info also. Are you going with the crank out windshield? It is pretty easy to just glue one in solid, no leaks.
1941 Chevy stock complete
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
1941 Chevy Coe uncertain future resting now
Taking it a step at a time, I'm hoping to integrate the wipers and electrical equipment into the 41 GMC, keeping the interior somewhat original looking. I'm also hoping to restore the crank out windshield. I've learned from a previous project to save everything.
Guess there was no saving that S10 box after you tore it into flinders 😂. It was probably fun to go at the S10 with your saw, but not as much fun disposing of the carnage. Good start, I’ll be following along.
1950 3100w/63K
Farm Truck: Fame-up restoration / modification
Follow the restoration story in his Project Journal
1950 Styleline Deluxe Coupe w/93K
O Online: Content
How close are the wheelbase and track dimensions between the two?
1950 Chevrolet 3100 (Ol' Roy)
1939 Packard Standard Eight Coupe (The Phantom) | 1956 Cadillac Coupe de Ville (The Bismarck) | 1956 Cadillac Sixty Special Fleetwood (The Godfather) | 1966 Oldsmobile Toronado (The Purple Knif) | 1966 Ford Mustang (Little Red) | 1964 Ford Galaxie 500 coupe | 1979 Ford F-100 | 1976 Ford F-150 (Big Red) | 1995 Ford F-150 (Newt)
AD Addict & Tinkerer
I’m glad you started a journal documenting your journey. It will be both educational and fun following your build.
Phil
Project Journals
Stovebolt Gallery Forum
The box being so rusty made it easier to tear apart, it wasn't worth saving. I'm saving anything I may need for the chassis and dashboard. I'm getting rid of all the external and interior parts such as the doors, box liner, box topper, hood, lights, etc... The track dimensions for the front wheels are identical, rear wheels will need a spacer. Wheelbase is 2 inches shorter on the S10,
e-zchassisswaps.com sells a kit for the conversion, all the hardware required for my 1941 GMC to fit the 2003 Chevy S10, including the hardware to move the rear axle back 2 inches, therefore no frame cutting required. If I understand right, the track is slightly different on the 2 wheel drive S10. Mine is a 4 wheel drive and matches the 41 GMC.
Moderated by  J Lucas
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.030s Queries: 16 (0.027s) Memory: 0.6325 MB (Peak: 0.7190 MB) Data Comp: Zlib Server Time: 2025-09-22 00:23:16 UTC
Valid HTML 5 and Valid CSS
