0 members (),
108
Mod | | | Forums66 Topics128,105 Posts1,056,539 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 34 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 34 | I have a 1950 3100 1/2 ton cab with 1952 doors. The passenger door rattles more than I would like. Should I be using the 1947-51 striker plates? Or should I be using the 1952-54 striker plates? | | | | | Joined: Mar 2010 Posts: 10,293 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,293 | '52-'54 striker plates for '52 doors, but you will likely need to hold your mouth just right to get the fit right. Maybe some lock pillar hammer massaging under the striker plate or a spacer there.
| | | | | Joined: Oct 2021 Posts: 6,885 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,885 | You must have one smooth running truck if you can hear the passenger door rattling over the valve clatter and wind noise.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | Here is a suggestion that might answer your problem: There was a rubber pad used on the 1952 doors that was different on some 1950 trucks I've seen. On most all of the 1950 trucks, there were 2 pads attached to the striker plate. On the 1952 trucks, the striker plates had no pads and the single bumper pad was attached to the door jamb a few inches lower than the striker plate. If you are using 1952 striker plates on a 1950 pickup, you may have no rubber bumper pad and this will cause some sincere rattling. Will rattle like a jackhammer banging on an empty oil barrel. I'd drill a hole and modify your cab to accept the 1952 style bumper pad. Also, the 1952 strikers adjusted differently and you may need to work on the adjustment a bit. Getting it just right can take some effort. New weatherstripping will help. Just don't buy the 11/16" weatherstrip product. It is just too big and will not work correctly. 1952 doors were designed to use a max of 7/16" ~ 1/2" weatherstrip. Good luck!
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
