3 members (1955 1 Series, Dave Richard, Buckeye998), 321 guests, and 5 robots.
Topics128,156
Posts1,057,021
Members48,460
#1584270 08/04/2025 1:01 PM
I have the rear window channels out of my doors as part of my restoration process but now find that one is missing the lower speed nut(s) and the other has 1 of the 2 screw holes stripped. They are unique double screw speed nuts that I am not finding available from the typical sources. One of the holes can be addressed by the use of an over the counter J type speed nut but the other is too far from both the bottom and side edges to allow a standard J type speed nut to work.
I am sure there are a lot of ways to get something to work but wondering what others have done before I try to reinvent a solution.
I know I can buy new channels that have the speed nuts but would prefer a more cost effective solution.
1949/50 3600 Project
Follow in Project Journals
On the top one, take a J-nut and cut the clip off of it and JB weld it inside the channel, although that may interfere with the installation of the window run channel in the trough. Or maybe you're talking about the speed nut holes that are on a flag piece welded to the channel.
Myself, I bought one new channel to replace a damaged one.
Professional procrastinator
Are you talking about this part?
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
I would bite the bullet and buy a one. You will add 3-4 years to the end of your life that way.
Cool. I guess I qualify for that benefit then. grin
Twin Jimmys, yes those are the parts.
klhansen, I am talking about the bottom of the channel, I beleive the flag end was formed from the parent material of the part, not welded on. I like the idea of just JBWelding a piece onto the one I can not get a standard J-nut to work on. The JBWeld would only need to hold it for assembly and if anyone ever tried to take it apart down the road.
I am pretty sure regardless of how I get this together it will out live me but buying new may be the best route as the existing channels have seen better days.
You can have this part if you pick up the shipping. I can cut the bottom off and it will weigh next to nothing in a small padded envelope.
Twin Jimmys, thanks for the offer but I need 2 of them so I will pass. Perhaps someone else can use it.
