Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
11 members (bucktruck, 2ManyTrucks, fonz8261, Peggy M, wilbur53, Gib70, greenie-reddy, 1942-G506, Lightholder's Dad, 2-Ton, Otto Skorzeny), 586 guests, and 1 robot.
Topics126,776
Posts1,039,258
Members48,100
Most Online2,175
Jul 21st, 2025
I’ve looked through and couldn’t find what I was needing (my search skills aren’t that great). I was hoping one of you could verify the orientation of the 4 outside boards.
The ends boards I “think” are correct(4 1/2” boards).
The 5” boards with the offset hole drilled in it I’m not sure which is which. I’m guessing the hole is closer to the cab but not sure.
Also on the 5” boards the hole is drilled offset (not centered) so not sure if the offset favored the middle or toward the bed sides.
The bed came with nothing as far as boards or hardware and it’s on an S10 swap so I’m lost on this one.
Pictures would be great or first hand knowledge!
Thanks in advance!
1953 Chevy 3100
   235, 3 spd. Mostly original so far
"The 1953 that Came Back"
Follow the build in the DITY Gallery
I believe you have it correct. Confirm by measuring between the mounting holes on the frame for the front of the bed.
Here's a picture of my bed with the wood installed. You'll have to zoom way in on the pic to see the front holes.
L Online: Content
Kevin, I like the black painted boards, just like they came from the factory!
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
First-Thank you for the pic and confirmation.
And that bed looks great, rethinking on whether to stain or paint black.
Thanks again
1953 Chevy 3100
I vote stain. That is pretty enough wood that it would be a shame to hide the grain under paint.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
O Online: Content
Are you going for originality? If so paint it black.
If I were to stain it, I'd use Cabot solid black stain. You'll still see the grain but it will be dark like worn black paint.
1950 Chevrolet 3100 (Ol' Roy)
1939 Packard Standard Eight Coupe (The Phantom) | 1956 Cadillac Coupe de Ville (The Bismarck) | 1956 Cadillac Sixty Special Fleetwood (The Godfather) | 1966 Oldsmobile Toronado (The Purple Knif) | 1966 Ford Mustang (Little Red) | 1964 Ford Galaxie 500 coupe | 1979 Ford F-100 | 1976 Ford F-150 (Big Red) | 1995 Ford F-150 (Newt)
Kent
Thanks, that's what I was aiming for. Everything on my truck looks original, except that I had the running boards shot with bedliner so it won't wear off like paint would.
I used a black stain that was recommended to me by a guy who said it holds up well to winter weather on decks in Fairbanks.
The offset holes are associated with the bed mounting to the frame. Given that you are working with an S10 conversion the "standard" board location may not match up with your frame.
In addition to lining up with the mounting holes in the frame make sure that the holes line up with holes in the cross sills. I recently assembles my bed only to determine that I needed to loosen most of the bolts to shift the boards to allow those frame mounting bolt holes in the boards to align with the holes in the cross sills.
1949/50 3600 Project
Follow in Project Journals
Thanks for the advice all. Still need to tighten it all up but it laid out well with only a few issues.
1953 Chevy 3100
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 1.212s Queries: 17 (0.061s) Memory: 0.6371 MB (Peak: 0.7320 MB) Data Comp: Zlib Server Time: 2025-09-22 00:23:23 UTC
Valid HTML 5 and Valid CSS
