The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (Green_98, Tiny, coilover, olezippi, 59 fleet, 68ironhead), 240 guests, and 3 robots.
Forums50
Topics120,036
Posts961,375
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
New Tech Tip - Timing cover mod for easy removal
#913369 Mon Jan 21 2013 10:58 AM
Peggy M Offline OP
Worker Bee
Thanks to Sweet for sending this one in.
As it starts:
Didja know, on most Stovebolt Sixes, the oil pan must be removed to get the timing cover off? And if you DID know that, didja come by that knowledge the hard way?? They says true wisdom is learning from others' experience. If you ever want to get at your timing chain without all the drama of dropping the oil pan first, all you have to do is make an easy...
Read the rest.
Peg
Re: New Tech Tip - Timing cover mod for easy removal
Peggy M #913381 Mon Jan 21 2013 11:44 AM
Definitely a good tip that many of us have used. The only thing I would suggest is to use allen head bolts as opposed to hex head because there can be a wrench/socket clearance issue with the cover in installing and removing the hex head bolts. Using a handled allen wrench alleviates that issue.
Drew
Peggy M #913413 Mon Jan 21 2013 02:11 PM
NOW you post this!!!! grin
1955 2nd chevy 4400 series 1.5 ton, affectionately named Mater
1969 GMC Heavy Half LWB fleetside with TH400 305 v6 named Blue Thunder
Miss Daisy, the 1949 Dodge Coronet 4 door with Gyromatic transmission
Project While-I'm-at-it, the 1972 GMC Sprint (5.3LS with 4l60e swap underway)
Some people are like glo sticks, I just want to snap them, and shake the snot out of them until the light comes on!!
Peggy M #913728 Tue Jan 22 2013 01:51 PM
My word, but that's a nice-looking engine!
And, I might add, this tech tip work only cost me three beers (I think SWEET would have done it for two, but I'd have paid a case).
Looks great.
Jim
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
In the Stovebolt Gallery [stovebolt.com]
Peggy M #913737 Tue Jan 22 2013 02:47 PM
ODSS Lawman
Well then, looks like I need to stop by for a few cold ones!!
SWEET
Sergeant At Arms
Old Dominion Stovebolt Society
BUNS?!?!?! Where we're going, we don't need no buns.....
1950 GMC 450 (25% owner)
1951 Chevy 1/2-Ton
The GreenMachine
Peggy M #914839 Sat Jan 26 2013 02:20 PM
WHOA, just read the Tech tip and it says to use a 3/8 drill bit to drill and tap for a 3/8-16 bolt.Should this not read drill the holes to 5/16 inch and tap to 3/8-16? Jerry
Peggy M #914918 Sat Jan 26 2013 08:13 PM
OK, Here is what I found on the 235 block that I am getting ready to replace my 1951 chevy 216 engine and trying to follow the original posted tech tip. Will this mental torture ever end? The 2 lower bolts removed from Inside the pan threaded into the timing gear cover were 5/16-24 grade 5 bolts. When I fit a 5/16 drill bit shaft into those 2 block holes, it is sloppy loose.That is the bore size I would use to thread the 2 holes to 3/8-16 as per tech tip. Going up in size in drill bit diameter, I find that a 21/64 inch drill bit just fits the existing hole. looking at my US Tap and Drill Bit Size Table, that is the exact size needed for a 3/8-24 inch bolt. Please, I already drilled out the Timing gear cover to 3/8 inch. Is my block a misfit? Thanks to all for guidance! Jerry
Peggy M #914952 Sat Jan 26 2013 10:33 PM
Only the cover needs to be drilled. The holes in the cap can be tapped as is, as 51 said above.
My TRUCKS website
Peggy M #915819 Wed Jan 30 2013 01:58 AM
Please read the tech tip carefully. It does NOT say to drill the bearing cap . Just the covers.
Dusty #915864 Wed Jan 30 2013 08:14 AM
I used to drill and make them removable from the front in the early 70's i also modified the front of the block to get the extra oil in the cover to drain back to the pan faster. This was easier than adding a fitting and drain line to get it back to the pan.I learned the oil drain trick from some of the old timers that raced these old engines on circle track and speed trap runs.
If you modify the block to drain the oil from your timing cover, the gears explosions will end and RPM will increase dramatically. My old 6 was built in the 70's at and has a lot of miles on it and has seen RPM's way over the normal range.
Page 1 of 2 1 2
Moderated by  Woogeroo
