Holidays are over
Hunkering down for winter ... how about your truck?
Forums59
Topics128,262
Posts1,053,040
Members46,578
Most Online1,229 Jan 21st, 2020
#831739
Sat Mar 03 2012 03:54 AM
OP
Will a fresh air heater from a '53 work in a '54? Thanks.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
Yes it will. Hope you got the cable with it.
OLTrucks
Unregistered
Yes, same heater, The "Air Flow" heaters came out in 1953 and was the same (except the control knob)till 1955 1st Mike
OP
Thanks for the info. If you're meaning the defroster cable. no, I didn't get that with it. There's a wrecking yard around here that has several AD trucks in it. I might get lucky nd find one there. I did once before.
On a 53-55 Advance-Design truck outside-air "De Luxe" heater (AirFlow, Fresh-Air), there is no defroster cable (as was used on the earlier style, similar "De Luxe" heater).
The cable in 53-55 is used to open and close an interior-air/exterior-air door on the right-front face of the heater (to regulate between blowing/heating all outside-air to all inside-air).
The 53-55 defroster-lever is hand-controlled (or, maybe, foot-controlled) using the lever on the left front of the heater unit (as used on the recirculating heater).
