The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (homer52, Rsqwhite, 2ManyTrucks, Steelonsteel, booger), 100 guests, and 3 robots.
Forums60
Topics127,485
Posts1,031,819
Members45,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
transmission adapter 1946 bellhousing to T5
#80364 Tue Jul 24 2007 03:23 AM
I am looking for a transmission adapter to put a T5 transmission in my '46 truck. I am using a '57 235 with '46 bellhousing, etc. Does anyone know where I can find an adapter?
Re: transmission adapter 1946 bellhousing to T5
#80365 Tue Jul 24 2007 03:29 AM
Do you need one?
I thought the SM420 would fit the older bell housings, and a t5 fits anywhere a sm420 fits?
•1951 GMC 250 in the Project Journals [stovebolt.com]
•1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
•1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
#80366 Tue Jul 24 2007 03:57 AM
Buckeye...
Look in the Tech Tips as there is an article that outlines one way to do it with an adapter plate. You could also get a bellhousing from a 48-53 truck that has had something welded to it to mount your clutch and brake pedal. I had an adapter plate made locally for my transmission swap in my 1940 gmc. It was a bit spendy.
Look up Buffalo Enterprises as he has made seeveral of those adapters for that swap.
#80367 Tue Jul 24 2007 06:37 AM
Using an adapter should eliminate the necessity of lengthening the the transmission splines and shortening the input shaft so that you can replace the transmission at a later date without having to modify it.
#80368 Tue Jul 24 2007 07:34 PM
Buckeye - You can get an adaptor plate from Buffalo. I don't have the phone no. right now but you can do a search here and find it easily.
I used one from buffalo on my T5 transplant. It worked great. Around $140
Good Luck
George
#80369 Tue Jul 24 2007 08:50 PM
Buffalo Enterprises in Arlington WA. 360 652 7684
#80370 Wed Jul 25 2007 03:38 AM
Thank you all for the help. I will give Buffalo Enterprises a call.
Your help sure makes this project a whole lot easier. I may be back with more questions later. When I finish my '46, I've got a '50 COE to work on.
Thanks again
Buckeye Phil
#80371 Thu Jul 26 2007 08:43 PM
Buckeye, here is a link, the site may be up now if not all the other info is there.
http://inliners.org/buffalo/
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#80372 Sat Jul 28 2007 10:20 PM
It figures someone makes a adapter after I bought a modified bellhousing from Jim carters. Jeff
#80373 Wed Aug 01 2007 08:55 PM
Anonymous
Unregistered
But does that adapter have mounts for your pedals to bolt to? I looked at their page but couldn’t see any item pictures. Anyone seen one ? sure would be sweet.
Page 1 of 2 1 2
Moderated by  Woogeroo
