The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
That time of year with some last chances to get together in bunches. Time to check out:
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: the ODSS gathers this week (Sept 22-24) at a yearly ATHS show in Winchester VA.
Since we put up this promo last week, a bunch of new postings of Swap Meets, Cruisin's, and more
in the SIDE LOT.
See what's happening with a Stovebolt Collective near you
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (Peggy M, delky, baldeagle, klhansen, 1 invisible), 104 guests, and 3 robots.
Forums60
Topics129,095
Posts1,046,670
Members46,191
Most Online1,229
Jan 21st, 2020
#603523 Tue Dec 22 2009 08:06 PM
ornge58 Offline OP
Apprentice
Howdy! Does anyone know if there is an adapter kit made to put my 53 chevy truck on an s-10 frame--- OTHER than from ad-engeneering (MAN--are they EXPENSIVE!!!!)
Thanks!
I don't know of any other kit.
I have no idea what the kit costs or what is in it but I will say this. If you were to make a swap like this on your own you would spend countless hours figuring what needs to be built, how to build it, gathering materials and building it. There will be lots of trial and error and re-doing. It will make less of a dent in your wallet but will cost way more in time.
This same fact is true with many aspects of rebuilding an old truck. Take disc brakes for instance. You can buy the kit or you can fabricate your own brackets, scrounge around junk yards for used serviceable parts, re-build them and try to make it work.
Depending on what your time is worth to you, it might be less expensive in the long run to get the kit.
My TRUCKS website
Hey Cletis, I saw the AD Engineering website and looked at their photos and gallery.
It seems to me that the truck would sit pretty low on an s-10 frame.
Is the road clearance really lower, or is it just my imagination?
Thanks!
There is a second company making a kit. I'm not sure they are any cheaper than AD Engineering.
Lots of people have done this swap without a kit. If you are good at fabricating there is no reason not to tackle it on your own. If you're going to need to hire a fabricator to make your mounts you'll spend less money buying the kit.
The AD Engineering kit puts the truck at about stock ride height.
Its true, I really don't do anything but browse the Internet looking for trouble...
Steve@OldSub.com . www.OldSub.com . www.MaxwellGarage.com . www.OldGasTowRigs.com
'55 1st GMC Suburban . '54 GMC 250 trailer puller project. '54 GMC 250 Hydra-Matic . '54 Chevy 3100 . '47 Chevy COE . and more...
Thanks!
I guess its just my "predjudice" kicking in grin - imagining a lower road clearance.
I really don't like the idea of putting a old vehicle on a modern frame. Sorta takes away from the "classic" stuff.
All I agree with is upgrading to things like power-discs, modern buckets with built-in seat belts and harnesses, and hopefully, a collapsable steering column.
So I guess I'm talking "semi-original". cool
KC Mongo has a kit as well for swapping a complete frame
if you just want the front suspension without the issue of the radiator interfering with the steering box, let me know, I sell a crossmember. http://www.stovebolt.com/ubbthreads...;Main=84625&Number=595038#Post595038
PM me for details.
Orange58,
There is one other option I did on my 46 4 door years ago.
Chassis Engineering makes a BOLT-IN for the front and the rear.
Just clean up your frame,drill a few holes and you are set.
The front uses stock Mustang II that you can buy from them or go to the parts house and get springs,bushings,Granda bearings and 11" GM calapers. I put 85,000 miles on that car before building a Pickup. Just another Idea.
Sully
50 chevy 3100
Here is a write-up using teh ez chassis swap
http://chevytrucks.org/tech/s10_frame_swap.htm
Or you can do it yourself
http://www.jalopyjournal.com/forum/showthread.php?t=8491
http://www.jalopyjournal.com/forum/showthread.php?t=144798
Either way, an S-10 frame swap involves being creative with the radiator and steering.
Moderated by  Justhorsenround
