Forums64
Topics129,449
Posts1,067,360
Members46,937
Most Online1,229 Jan 21st, 2020
#16550
Wed Aug 06 2003 09:50 PM
OP
Moderator, Passing Lane
Is there a way to jump start a 6 volt system with a 12 volt, I have never heard of it but a friend said he thought you could but did not know how to do it,,,True or False, I have a need to start a 6 volt tractor this weekend but will probably be by myself so I will not be able to push or pull it,I could get a new battery but..Fred
RedryderMy HotrodI am fighting cancer and I am winning the fight A veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."Pain is part of life; misery is an option.
#16551
Wed Aug 06 2003 11:40 PM
Anonymous
Unregistered
Hey Fred, to jump start 6volts from 12 volts just connect the postive to postive and negitive to neritive(Make sure ya got it grounded good) and listen to it sing. tony'n weatherford(TEXAS that is)
#16552
Wed Aug 06 2003 11:56 PM
OP
are you tricking me? that would be the same way as 12 volt to 12 volt, are you saying it does not make any difference?? run that one by me again, please.......Fred
#16553
Thu Aug 07 2003 12:27 AM
You can jumpstart a 6 volt with 12 volts, but the safe way to do it is with the key off. Use the 12 volt to impart a charge to the 6 volt battery and then disconnect it before you try to start the engine, otherwise you might fry your gauges and generator/alternator.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic.
#16554
Thu Aug 07 2003 03:16 AM
Back when I was still running 6v, I was constantly jumping my truck with a family 12v battery. Yes, it might not be the best thing for it, but when you are desperate.......
Craig's '50 Chevy 3100 5 window, 235cu My truck [ cmaynard.com] If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
#16555
Thu Aug 07 2003 03:46 AM
OP
will the battey really get that much of a charge without the 12 volt truck running just by battery to battery,,,,,Fred
#16556
Thu Aug 07 2003 04:26 AM
I've had a number of 6V vehicles, and they were all jumped from a 12V a time or 3 - just keep it quick and unlike same to same, do not do it w/ the 12V running, also get the + jumper off the instant the 6V starts - hard to do quick alone, but ya might be able to w/ a tractor
Thu Aug 07 2003 04:43 AM
You can start 6V with 12V You must put one foot in a bucket of salt water to properly ground you.(Shoe off) Attach the pos to both posts and neg to the 12V side Now this is the tricky part: You must figure just how many fingers to touch the 6V neg post with to get proper resistance Note If the resulting spark leaves a black hole in your finger see a Dr as soon as you quit jumping
#16558
Thu Aug 07 2003 04:54 AM
I want some of whatever Jim is having Joker, you can jump with the 12 volt but likt squeeze said, disconnect the 12-v jumping battery as soon as the 6-v unit starts. Not a problem
#16559
Thu Aug 07 2003 04:19 PM
Back when I had my 6v VW bug, the darn thing would never start when hot. The battery is under the back seat. So, I had a second battery there that was 12V. I would just flick up the seat behind me and touch the jumper cable to the 12V and VVRROOMM.
Joker, you can do as suggested. Hook the two vehicles together and leave the 12v running for 15 or 20 minutes. The 6v battery will get a real nice charge in that time. If it won't start that way just do a regular jump. I doubt the tractor has too many electronic gauges anyway.
Do the regular jump with the 12v engine off. That way you are only using battery power and not higher alternator power.
54 3100 with 235 62 flatbed dump C60 with 261
