What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
1 members (Fox),
92
robots. |
Key:
Admin,
Mod
Forums59
Topics128,567
Posts1,041,570
Members46,048
Most Online1,229 Jan 21st, 2020
#547555
Wed Jun 17 2009 07:56 PM
OP
Any help with a horn installation on 1948 Chevy 1/2 ton truck is appreciated--6 volt system. How many horns, type, where placed, and wiring detail needed. Thanks-- HONK-HONK!
The original had one horn mounted on the intake manifold wired direct. You can use any 6 volt horn or horns & mount them on the inner fenders, frame rails, or core support. I would use a relay in the system. Run the hot wire to the bat term of the relay. Run a wire from the horn/s to the horn term. Run a wire from the steering column to the button or switch term. Use 12 gauge wire on the hot lead & to the horn/s. The button wire can be small gauge, 16-18.
1972 Chevy c10 Cheyenne Super
OP
Thanks for the info. Are there any pictures or diagrams available as well? What would the original horn have looked like? I have seen the coiled-type horns, as well as the cone-shaped horns; did it matter which one was used? I will take all the advice that I can get--much appreciated. BEEP-BEEP
The original was probably one of those big, cone shaped ones. But if you're not concerned about originality, then, as was mentioned, any 6 volt horn will work.
