BUSY BOLTERS
Are you one?
The Shop Area
Forums65
Topics123,420
Posts999,267
Members47,276
Most Online1,229 Jan 21st, 2020
#899436
Mon Nov 26 2012 05:49 PM
OP
I came across a good deal I think... Its a 51 GMC 2 or 3 ton (19000 gvw) flat bed truck sitting on an old farm. Its pretty solid with the exception of the the lower right cab corner and drivers side floor board. Looks like the original motor and owner says he thinks mileage is correct at 53502 miles. Tires, wheels and frame look real good as does all glass except passenger side door. Its been sitting several years but motor turns over and was running when last parked... Its painted in military od green, inside and out and was an old army truck on the military base here... The owner is asking $400.00. Anybody wanna weigh in on this being a fair deal or not ?
Thanks, Troy
That's less than scrap (you can't get hurt for that kind of money)...why aren't you anouncing this as you newest toy...what are you waiting for? Mike B
OP
Thanks for the reply, Mike  With your expert opinion and the price of many others i see advertised, most all over $1000, I probably will pull the trigger on this one right away... After purchase I will try and upload some pics. Thanks again  Troy
I would agree. Get it before the guy changes his mind!
If it's 19000gvw it's larger than a 2 ton. Should be a GMC 400, 450, or 470 series. May have series designation emblems on the hood. Being Military, no telling what it might be. Any pictures. $400 is a steal regardless.
OP
Unrepentant VW Lover
Troy, You're not ignorant. I just fixed the code a little for you (Next time, make sure the Markup box says "Using UBB code" instead of HTML.) No sweat, I have a soft spot for folks from Bammy (I married one and both our daughters are B'Ham born  ) Sorry for the hassle. That truck looks excellent -- grab it! John
OP
John, thanks so much for helping me out there... I really appreciate it... Its an honor too, having you, the main man no less look at and fix my mess Anyway, I'm sure glad you like the truck...several others have said I cant go wrong so tomorrow I go to make the deal. I cant wait ! Thanks for the 'bama plug too  Troy
OP
Mr. Hardy, the serial number on the data plate on inside of door area gives serial number hc453. Does that tell us anything ?
Troy
Yep, That's a 450 series 3 ton , with 161in. wheelbase. Being a '51 model, should have a 270ci. six banger. There should be a "GMC Parts Identification" tag, on the back of the glove box lid, with all the trucks specifications.
