Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
17 members (Bob King, 58NAPCO3600, Cosmo, 59 fleet, D B Cooper, 2 invisible), 682 guests, and 7 robots.
The Zone
Forums65
Topics123,421
Posts999,134
Members47,256
Most Online1,229
Jan 21st, 2020
Page 5 of 5 1 2 3 4 5
Guitplayer #1504949 Mon Jun 12 2023 09:20 PM
Herder of Cats, Goats, and Sheep (moderator)
Also, if you add a keep alive circuit, make sure it is not connected back into the main circuit or you can backdraw through it when the switch is off.
Most radios these days have separate BATT and IGN connections, so you don't need to worry about it there. For custom installations, just be careful.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Apache, long bed Fleetside, V8 w/SM420
Driveable but the rear axle needs work.
1959 Apache, long bed Fleetside that has been in the family for 25 years but in desperate need of love.
Fibonachu #1504954 Mon Jun 12 2023 09:36 PM
Good advice. That would be a sure way to smoke a circuit the first time you forget to thru the main switch on before hitting the starter. If there's not a separate connection to your radio that needs constant power, a diode in the normal power circuit to the radio could be installed.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Guitplayer #1504957 Mon Jun 12 2023 09:42 PM
I had an undergrad (EE) student burn my electric humvee down by doing that. I would have thought it would be a lesson learned until he did it a second time...
The school wouldn't let me fail him, so he graduated and went to work for Dodge...
eeeek
Fibonachu #1504962 Mon Jun 12 2023 09:55 PM
eeeek
That explains some things. not me
Guitplayer #1504970 Mon Jun 12 2023 10:33 PM
AD Addict
You could install a small inline fuse on the bypass circuit so if you forgot the main switch, you will only blow the fuse.
1952 Chevrolet 3100
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
Updated to: 12v w/alternator, HEI & PCV
Guitplayer #1504986 Tue Jun 13 2023 12:41 AM
I never put an interrupter switch on a battery ground circuit for just that reason. Killing the power to the battery cable that supplies the starter will usually interrupt the voltage supply to the dash and ignition switch as well. Run an independent small diameter wire (with maybe a 5 amp fuse) to whatever needs a few milliamps of constant current to keep its memory functioning.
Guitplayer #1505019 Tue Jun 13 2023 03:52 AM
Sir Searchalot
I suggest we cut this off. This is as simple as it gets to wire.
Guitplayer #1505032 Tue Jun 13 2023 10:27 AM
Interesting. What would we cut off?
BD
1958 3100 Apache Step side 1/2 ton 327 engine
1958 3100 Apache Panel 1/2 ton 235 engine
1959 3100 Apache Panel 1/2 ton 327 engine
In Project Journals
Guitplayer #1505060 Tue Jun 13 2023 01:50 PM
I agree with Bartamos. Let's move on to other things.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
