Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
19 members (cmayna, 3B, COCOE, Danielbolt, BC59, 1 invisible), 752 guests, and 9 robots.
The Zone
Forums65
Topics123,421
Posts999,143
Members47,256
Most Online1,229
Jan 21st, 2020
Page 6 of 6 1 2 3 4 5 6
During a "normal" engine rebuild where the cylinders are bored over .0030 or .0060 due to normal wear and tear, how does this affect performance since the factory camshaft is usually installed.
1939 Packard Standard Eight Coupe (The Phantom)
1956 Cadillac Coupe de Ville (The Bismarck)
1956 Cadillac Sixty Special Fleetwood (The Godfather)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
A Chevy 350 bored .030" oversize goes to 355 cubic inches. That's 5/8 of a cubic inch per cylinder increase in volume. For all practical purposes, the increase in compression can be ignored. There needs to be a big increase in bore and/or stroke, or a dramatic reduction in combustion chamber size to make a big difference in compression pressure. That same 350 with a 76CC cylinder head has about 8.5:1 compression. A 64 CC head brings it up to around 9.5:1 or maybe 10:1. Domed pistons and a 64CC head approach 11:1.
A Chevy 230 six has flat top pistons. A 250 has a 1/4" dish in the piston top and uses the same cylinder head. That's a difference of slightly under 4 cubic inches per cylinder, from a longer stroke on the 250. The dished piston is there to keep the compression the same on both engines. Running a flat top piston for a Chevy 307 V8 in a 250 brings the compression up to about 9:1.
Thanks.
1979 Ford F-100
52Carl Offline OP
My engine was bored .060" over, and there is .050 missing from the bottom of the head, leaving most of the quench trench by the intake valves missing. The machine shop also put in all new valve seats at an unknown level. If the new seats were ground too shallow, compression would be even higher.
I did a hot compression check on all cylinders before I pulled the head, #2 through #6 were at 240 PSI (+/- 5 PSI), and the #1 with the leaky exhaust valve was at 180 PSI.
That is about 100 PSI too high. Its a brand new gauge. I doubt that the gauge is off by 58%.
When I do some major metal butchery on that head- - - -bigger intake and exhaust valves, recessing the intake valves back to the proper depth, opening up the combustion chamber around the bigger exhaust valves to unshroud them, and a few other kinds of metal butchery- - - -I'll have one of two things- - - -a really good-performing head that can be paired up with a pretty radical cam, or a boat anchor! I won't really know until I'm about 75% of the way through the job. If I end up making the head worse than it already is- - - -no big loss, as I can use the new valves in a different head if that one can't be salvaged. I've got a few other sneaky tricks up my sleeve for the engine, other than the cylinder head mods I've mentioned.
52Carl Offline OP
Yep. You are only into this for a delicious chicken sandwich, large fries, and a large Diet Pepsi.
I still say I came out ahead way ahead on that horse trade. I literally "ate your lunch." smile smile smile
LOL! If you've got another head handy, there's a second course waiting. There's a really good BBQ place a few miles south!
52Carl Offline OP
There's a gutton born every day.
AD Addict
Locking this thread! Story has gone full circle.
1952 Chevrolet 3100
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
Updated to: 12v w/alternator, HEI & PCV
