15 registered members (dougs, 66flea, Brad Allen, Apache1, darthintel, glenns towing), 366 guests, and 3 spiders.
Forums48
Topics116,159
Posts927,062
Members42,567
Trailblazer 6 bolt rear end #1314507 Sun Jun 16 2019 03:29 PM
coilover Offline OP
Just finished putting a 2000 Chevy Trailblazer 6 lug rear end under a 1950 3100. Fits great IF one uses the Trailblazers wheels. The bolt pattern is metric so 6 on 5.5 early Chevy wheels don't fit. Will have to make a "Uni-lug" wheel for a spare that fits front/rear. Should take about a half hour on the vertical mill.
[img]https://i.postimg.cc/0zKYy9bH/IMG-4866.jpg[/img]
[img]https://i.postimg.cc/1V6Szn13/IMG-4867.jpg[/img]
Evan
Re: Trailblazer 6 bolt rear end [Re: coilover] #1314508 Sun Jun 16 2019 03:34 PM
Hotrod Lincoln Offline
Boltergeist
How about modifying the front hub bolt pattern to accept the same wheels all the way around? Offset the hub lug holes 30 degrees and bore both hubs and drums for the new bolt pattern. That's also a pretty simple vertical mill or radial drill press operation in combination with a dividing head. Then use a donut spare for front and rear. If the wheels are hub-centric it might be necessary to make a spacer or machine the hub snout down, but that's child's play for an experienced machinist, also.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Trailblazer 6 bolt rear end [Re: coilover] #1314538 Sun Jun 16 2019 08:02 PM
coilover Offline OP
You're right Jerry, It's easy to make a new pattern when the lug count is the same. When going 6 to five or visa-versa that the set of new to old holes look like fresh snow with the footprints of a staggering drunk. The old Chevy is (in metric) 6x139.7 while Trailblazer is 6x127---almost a 1/4" smaller. Pilot hole is no biggy.
Evan
Moderated by  SWEET
