12 registered members (canuck49, cmayna, Grigg, Hotrod Lincoln, beltfed, Flatblu4748), 278 guests, and 2 spiders.
Topics115,209
Posts915,188
Members42,197
Page 2 of 2 1 2
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1316770 Sat Jul 06 2019 04:53 PM
Brian_Ostner Offline OP
Ok fellas.
Was at truck and tried to get it started.
Put bew battery in it.
Turned over fine...
No spark.
Pulled distributor cap to file pionts a little...
They were new along with condensor...
Had son hit foot stomp starter while i watched points first....rotor not spinnin...?
Pulled distributor...
Teeth busted off drive gear.
darn.
Wonderin why and now need new drive gear.
Also here are pics of #’s off manifold behind carb.
Brian
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1316771 Sat Jul 06 2019 04:53 PM
Distributor
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1316773 Sat Jul 06 2019 05:06 PM
tclederman Offline
Boltergeist
302 "D" head (2193983)
1952-1962
Also used on military 302 engines
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1316776 Sat Jul 06 2019 05:21 PM
Thank you very much.
Now need distributor drive gear
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1316792 Sat Jul 06 2019 08:00 PM
Grigg Online
See if oil pump is locked up.
Distributor gear shouldn’t strip for no reason.
1952 Chevrolet 3800 pickup
---All pictures---
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1316795 Sat Jul 06 2019 08:25 PM
sweepleader Offline
When checking the oil pump, be sure to look for damage on the drive gear on the cam. Not likely but you never know...
1962 K10 short stepside, much modified for rally
1969 T50 fire truck, nos, needs a few things
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1316948 Mon Jul 08 2019 01:46 AM
spanky Offline
So it is a GMC 302 6 cyl. Best engine, you could have wished for.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Re: 1952 GMC Dump..... [Re: spanky] #1317121 Tue Jul 09 2019 08:34 PM
So i found a complete distributor from one of our farm trucks.
Its a 1950 GMC 350.
It also has the 302 engine that has been used for spare parts in past....
So, i sprayed the distributor down so it would loosen up, hope to get it out today.
Gonna use the old distributor housing and center rod as a drive rod to spin oil pump.
But first i will make sure the oil pump is freed up.... I assume the oil pump is prolly stuck and that caused the distributor gear to get stripped.
Will also check cam gear for damage.
I will have to re-time distributor for No.1 cylinder as well...
Keep ya’ll posted.
Brian
Page 2 of 2 1 2
Moderated by  69Cuda, Grigg
Powered by UBB.threads™ PHP Forum Software 7.7.2
