10 registered members (glenns towing, HandyAndy, Just Mark, 49 3100, bwilliams, DaveV), 400 guests, and 3 spiders.
Forums48
Topics116,158
Posts927,059
Members42,567
Engine casting numbers. #1314059 Wed Jun 12 2019 05:40 AM
Beartooth-Cowboy Offline OP
I recently hauled home an orphan 1960 C10. The engine serial number looks kind of odd to me.
In the following picture are the I’s read as 1’s?
Thanks in advance,
To Our Veterans, a Grateful Nation remembers and thanks You! 🇺🇸
Re: Engine casting numbers. [Re: Beartooth-Cowboy] #1314115 Wed Jun 12 2019 09:06 PM
Lugnutz Offline
The casting marks indicate the date. Looks like conveyor #4 and cast on
L=December
19 = 19th day
9 = year but I’m uncertain about what engine you have because of the location of the serial number FI22IJC (both are i). If there is no road draft tube and the fuel pump is to the rear of the engine perch, then I’d guess you have a December 19, 1969 292ci engine.
Got any more pictures?
Re: Engine casting numbers. [Re: Beartooth-Cowboy] #1314118 Wed Jun 12 2019 10:01 PM
Lugnutz, thanks for your reply.
This has the road draft tube.
Fuel pump at the front of the engine.
Enclosed an overhead picture.
Re: Engine casting numbers. [Re: Beartooth-Cowboy] #1314119 Wed Jun 12 2019 10:09 PM
How do you read the engine serial number?
Is this the correct S/N for a 1960 235 c.i.?
Re: Engine casting numbers. [Re: Beartooth-Cowboy] #1314125 Wed Jun 12 2019 11:16 PM
Hambone Offline
Find the casting number per the link below and tell us what you find.
http://www.1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
1960 might have had a 235. Your date code L199 might indicate 1959 casting date. But it could be any replacement motor. Show us some more pictures.
Your valve cover have 4 fasteners?
I will move this post to the engine pages where you will get more insight if you dont get answer here.
HB
HB
1966 Chevrolet K-10
Flappy Fenders
More pictures on Photobucket
1962 Chevrolet C10
Re: Engine casting numbers. [Re: Beartooth-Cowboy] #1314161 Thu Jun 13 2019 03:16 AM
Thanks Hambone, it does have 4 screw fasteners on the valve cover. Pretty sure this is a 1960 235. Will need to get to WallyWorld do more engine degreaser to find the block casting numbers. Have gone through 3 cans of degreaser just to uncover what I have found so far.
How to read the engine serial numbers? Read where the suffix JC indicates 1960-1963 engines.
Re: Engine casting numbers. [Re: Beartooth-Cowboy] #1314182 Thu Jun 13 2019 10:10 AM
Hambone Offline
that is the head #. The engine block # will be down by the distributor. xxx848 is desired. Google chevy 6 cylinder engine identification and you will find a number of resources.
Send more pictures of the truck as well. We will get you started.
HB
1966 Chevrolet K-10
Flappy Fenders
1962 Chevrolet C10
Re: Engine casting numbers. [Re: Beartooth-Cowboy] #1314549 Sun Jun 16 2019 10:37 PM
tclederman Offline
Boltergeist
If you have not yet ID'd your engine head/block, find/post the codes at the locations shown on this page:
Engine Serial Number
Head date casting code, and head casting code
Block date casting cost, and block casting code
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Moderated by  Hambone
