14 registered members (55 SHAKER, Gary P., Hotrod Lincoln, coilover, 68ironhead, Green_98, 2 invisible), 317 guests, and 3 spiders.
Topics114,994
Posts912,361
Members42,071
disc brakes on a '49 #1311571
Thu May 23 2019 01:40 AM
52Carl  Offline OP
Virginia
I want to put disc brakes on my '49. I currently have Huck brakes on the front, and 1970 Bendix on the back.
So I am assuming that I will need a dual master cylinder. I want the one which goes under the floor in the original spot.
I have a Th400 transmission behind a 350 engine. Will the vacuum assist version fit next to the automatic transmission?
How about proportioning valve?
How about interference between the axle and the caliper on hard turns?
Re: disc brakes on a '49 [Re: 52Carl] #1311578
Thu May 23 2019 02:06 AM
Justhorsenround  Offline
Grease Monkey
El Reno, Okla
My son’s ‘53 has under the floor power brakes w/dual master cylinder. The truck is a 350/700r4. He is running a proportioning valve. Camero subframe so the rubbing is not an issue. 🛠
Martin
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: disc brakes on a '49 [Re: 52Carl] #1311611
Thu May 23 2019 12:21 PM
showkey  Offline
Wausau WI
Dual master.........yes
Proportioning valve .........yes
Axle interference on tight turn ...................Huge discussion point, reality is makes little or no difference when driving.
Automatic trans clearance ................not sure. My 1950 GMC 6 cylinder 4 speed manual is close and needs a right angle speedo drive to clear.
Re: disc brakes on a '49 [Re: 52Carl] #1311819
Fri May 24 2019 05:43 PM
just-a-hacker  Offline
Midcoast Maine,usa
I did need to put a different master cylinder on mine,mounted in original position.
I did not need any vacuum .
The kit I used was pretty easy to install .
Mine is also a 49
I used http://www.ecihotrodbrakes.com/ mainly because I could visit their shop and see operation, then I was able to pick up there
just-a-hacker
'49 3100 before '99
Re: disc brakes on a '49 [Re: 52Carl] #1311835
Fri May 24 2019 07:23 PM
Lindsey  Offline
Yellowknife
While looking into brakes for our '53, I was told master cylinders put out different pressures depending on brake type, drum vs. disc.
The issue with vacuum assist is apparently clearance with the manual transmission side linkage typically, which is why most say they only work WITH an automatic transmission, or likely with a floor shift manual.
Not sure about axle/caliper clearance. I decided to stick with drums all around for now but ordered a dual master cylinder for a little extra safety.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
