The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (Joe H, D B Cooper, lastchancetowing, Jon G, 3B, Gooberdog), 288 guests, and 3 spiders.
Forums47
Topics116,112
Posts923,265
Members42,338
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 3 of 4 1 2 3 4
Re: door alignment on 53 [Re: tclederman] #998798 Sun Jan 12 2014 06:38 PM
basham Offline OP
what i used was a combination of those pins and bussing and the ones with the longer pins i already had laying around. I think it's just time for new hinges.
Re: door alignment on 53 [Re: basham] #1001479 Fri Jan 24 2014 01:09 AM
basham Offline OP
Well, I can't win. Installed the new hinges and replaced the weatherstrip on the drivers door, the correct way this time and still can't close it. This is driveing me nuts. Any advice.
Re: door alignment on 53 [Re: basham] #1001841 Sat Jan 25 2014 02:35 PM
DADS50 Offline
Can you pst a few pictures.
Re: door alignment on 53 [Re: basham] #1002136 Sun Jan 26 2014 07:55 PM
nels1954 Offline
I bought new hinges from the Truck Shop. Installed the new hinges and neither door would close. Tried to adjust both hinges on the door. Removed the new hinges and reinstalled the old hinges. Then I was able to close the doors. I took the new hinges apart for an inspection. The new hinges were drilled off center. No wonder there was a problem. So I rebuilt the old hinges. Now the doors close and open correct. The new hinges are junk. Plan to write a letter to the complaint Truck Shop.
Larry
661-406-8496
1955 1st 3100
More pix
1954 Bel Air
Re: door alignment on 53 [Re: nels1954] #1002865 Thu Jan 30 2014 01:02 AM
basham Offline OP
Been messing with my doors and put new striker plates on today for a 53 and got the drivers door to close on 1 click. I'm starting to wonder if i have the right door latches. How can i tell if the latches match the strikers. The new strickers look different than the ones i took of the truck. Is it possible someone has mis matched the door looks and striker plates. I bought the new strikers from classic chevy for a 53. Maybe a picture of each.
Re: door alignment on 53 [Re: basham] #1002873 Thu Jan 30 2014 01:37 AM
truckernix Offline
If you take the striker plate off, does the door close flush with the cab? If it doesn't then the problem is not the lock or plate.
1951 1 Ton Completed
Re: door alignment on 53 [Re: truckernix] #1003099 Fri Jan 31 2014 12:33 AM
basham Offline OP
I really have to put my weight into it to close it. but it will close. Still about a half inch from touching at the bottom. Going to have someone help me this weekend. cause it's going to be a two person job.
Re: door alignment on 53 [Re: basham] #1003159 Fri Jan 31 2014 04:03 AM
truckernix Offline
It sounds like your doors are binding, maybe at the front post/cowl. If that is so and you push hard enough, you will bend the area and cause damage that is very hard to repair. I am just trying to give you a head's up.
Re: door alignment on 53 [Re: basham] #1012532 Sat Mar 08 2014 12:30 AM
basham Offline OP
Ok. back on the doors again. Yes, it feels like they are binding at the front or at least it feels like it. Again, gaps are good new striker and clip kit on latch, new hinges and the old hinges fit the same as new. belt line is good. I have the striker plate adjusted to where the door will latch ok but from the belt line down it tapers from a little to 1/2 inch out at the bottom. Doors used to fit alot better before i took them off the truck to paint. Getting very frustrated. door closes freely to about 2 inches from closing but once I get to that part i have to push on in. Need more ideas. Thanks.
Re: door alignment on 53 [Re: basham] #1028015 Mon May 12 2014 02:21 AM
CraigK Offline
The rubber needs to be *trained* to go flat ( shrink ) into place. I have heard of guys having to use bungie cords to get the doors close to closed, let them sit for a week, then they will start to catch on the latches. How did you make out anyway? I spent 6 months on the cab, and have 3 months into the doors and they still don't fit right. But they work. I am just never going to be happy with the lines.
Page 3 of 4 1 2 3 4
Moderated by  48bigtrucks
Powered by UBB.threads™ PHP Forum Software 7.7.3
