The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (Gazz, carryall jerry, Hotrod Lincoln, dougs, Barnfind49, 55 SHAKER), 321 guests, and 3 spiders.
Forums47
Topics116,096
Posts923,071
Members42,329
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 4 1 2 3 4
Re: door alignment on 53 [Re: basham] #998015 Thu Jan 09 2014 04:54 AM
bluedot38 Offline
Thinking that Steele Rubber has some online videos on UTube as well, helpful info. MIke
Re: door alignment on 53 [Re: 52Carl] #998194 Fri Jan 10 2014 12:44 AM
basham Offline OP
Looks like the drivers door seal is wrong. Don't know how I did that. Passenger door looks right, but will not shut either. I"ll try adusting it some more as i really have'nt messed with it. So, what's the best way to remove the new seal from the drivers door. Yes, doors are fun.
Re: door alignment on 53 [Re: basham] #998221 Fri Jan 10 2014 02:38 AM
52Carl Offline
Pull and pray. The adhesive should stay on the door. The problem will be getting the seal off in bigger than shelled peanut sized pieces. I wouldn't worry about removing the adhesive from the door as it should be OK to add new adhesive over it.
Re: door alignment on 53 [Re: 52Carl] #998223 Fri Jan 10 2014 02:50 AM
basham Offline OP
kinda what I figured. I'll get started. thanks.
Re: door alignment on 53 [Re: basham] #998226 Fri Jan 10 2014 02:57 AM
Achipmunk Offline
Had to take one of my rear door strips off the panel. I rubbed some gasoline on the side of it, peeled off what would come off then used a rag soaked in kerosene to get the rest of it off.
Not saying its the right way but its what I had in the shop and it worked. Kind of slow go but not that bad.
Pictures in my Photobucket
52 Chevy Panel
Re: door alignment on 53 [Re: Achipmunk] #998637 Sun Jan 12 2014 01:27 AM
basham Offline OP
After taking a look at the passenger side, it look like the seal is on correctly. I adjusted the door but it still won't close. when lifting up on the door i notice a little movemet. Now i think the hinge is not tight. Maybe it's just time to buy new hinges. Ouch.
Re: door alignment on 53 [Re: basham] #998678 Sun Jan 12 2014 03:26 AM
Achipmunk Offline
basham, there is a tech tip for rebuilding the hinges. I've rebuilt quite a few of them for myself and for others. Just follow the tech tip...... I will say that if the pins are hard to come out then heat them, or take them to someone who can, and get them out without destroying the hinge body or the tongue. You can do it and save monneeeeeey.
52 Chevy Panel
Re: door alignment on 53 [Re: Achipmunk] #998695 Sun Jan 12 2014 04:50 AM
basham Offline OP
I've already rebuilt them. thers is still some slop.
Re: door alignment on 53 [Re: basham] #998763 Sun Jan 12 2014 04:36 PM
DADS50 Offline
Re: door alignment on 53 [Re: basham] #998783 Sun Jan 12 2014 05:58 PM
tclederman Offline
Boltergeist
basham,
Did you rebuild them with over-sized pins? If thety are still loose, those pins were not over-sized enough.
I have successfully used these hinge-pin repair kits when I could not find tight enough over-sized pins.
As you have probably figured-out, if your pin holes are too "wallowed-out", new/replacement hinges will be needed.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Page 2 of 4 1 2 3 4
Moderated by  48bigtrucks
Powered by UBB.threads™ PHP Forum Software 7.7.3
