Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
17 members (BC59, 3B, Danielbolt, cmayna, COCOE, 3 invisible), 705 guests, and 9 robots.
The Zone
Forums65
Topics123,421
Posts999,143
Members47,256
Most Online1,229
Jan 21st, 2020
Page 3 of 4 1 2 3 4
Welcome JW51. The only stupid question is the one you don't ask. Cruze around the Stovebolt and you will know where to go with all your questions and you will get all the help you need.
"One thing about trains, it doesn't matter where the're going, what matters is, deciding to get on." - Polar Express
Only 1 thing to say....you are one lucky son of a gun! Who finds one of these old trucks with original wood and paint? I'm fairly new here as well, and initially there is so much info, that it is a bit overwhelming..I'm sure I haven't even scratched the surface,but two sites I've found helpful are Deve's and Tim Clederman's. I know there are many out there I haven't found yet and I haven't nailed the link business yet so can't stick them in, but if you click on their usernames you can navigate there.
Good luck !
Allen
1974 Stingray Corvette
Leo Offline
Good luck !
Seeing as you have a 51, be sure to check 'Dad's 50'. He has hundreds of excellent photos, sure they can be of help to you.
great truck! looking at pics i see the wood in the bed appears to have been stained or painted black. do you know if that is from the factory. curious since i too pulled a 52 from a barn in alabama back in 96 and my wood showed evidence of black but my reading says it was unpainted/stained from the factory. my truck, a 1 owner at the time is in the gallery as pete black's 52. i used fine rubbing compound applied by hand and numerous coats of wax to bring back the shine although the paint is thin in places. envious of your find
1952 Chevy Pickup Truck
JW51 Offline OP
I know trucks from the 60s typically came with wood bed painted black.
I'm new to this era of truck, but assume it's the same thing. Someone more schooled could comment.
Concerning wheels: I bought a set of 16 inchers off ebay (I think they came off an Old Navy truck). Check the width, some are 4 inches and some are 4-1/2. I ended up with a set of 4 inchers although I really needed a set of 4-1/2.
Joe
1955 First Series 3100
BTW that is correct on the black painted wood bed (yellow pine).
Joe
Advance-Design & New Design GM trucks' bedwood was black. The blackening substance seems to a subject of debate/conjecture.
Jim Carter write-up on bed wood.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
JW51 Offline OP
I think I will try to coat what remains of the black paint with some kind of oil finish.
Hate to make it black again because then you can't tell how old it is.
Nice find. Good luck
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the Gallery [stovebolt.com]
In the DITY Gallery
More images in Flickr [flickr.com]
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr [flickr.com]
1953 Chevy 1-Ton
Page 3 of 4 1 2 3 4
