Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
17 members (49.3600, 2-Ton, 78buckshot, 3B, 52Carl, breezy), 704 guests, and 2 robots.
The Zone
Forums65
Topics123,421
Posts999,149
Members47,256
Most Online1,229
Jan 21st, 2020
Page 2 of 4 1 2 3 4
JW51 Offline OP
Originally Posted by Marko2727
Your posts sound just like mine over the last few weeks. I have a eye bolt well screwed into the back wall of my garage that I use with a come-along to get projects into the garage. My first project was to get the old girl running because the seller offered to refund a third of the selling price if the engine is shot. Don't feel bad about posting pictures, I've been trying for 2 weeks and clearly suck at it. Good luck on your project.
Funny you say that, I've had the exact same thought about the come-along. Two fears have kept me from trying it just yet:
1) Wouldn't have a way to stop the truck if the cable broke (hence hiring that done)
2) Afraid I might pull the stud out of the garage wall to which the eyebolt is attached.
JW, as you spend more time on this site you will realize what an AMAZING truck you have found! I would probably put new tires on it but that would be it. (aside from anything mechanical it needs)
Congratulations on a wonderful find.
Joe
1955 First Series 3100
JW51 Offline OP
Joe
Thanks, it is in pretty remarkable shape. Looks better in those pics than in real life, but your thoughts are mine exactly. I think it'd be a shame to restore the body (plus I'm too cheap anyway).
New tires are high on my list. Whitewalls. Would also like to find some wheels to get away from the locking ring ones. Hard to find 6 lug.
Actually 6-lug wheels are pretty common, if you don't mind running non-original ones while you're looking for period-correct wheels. Virtually all the Nissan, Toyota, Mitsubishi, and other import truck 6-lug wheels run the Chevy bolt pattern. If you can find 15" wheels for an older Toyota Land Cruiser, they'll bolt on and look almost original, and there's a huge selection of suitable-size tires available. For 16" wheels, look into 6-lug plain steel trailer wheels. Just don't tell the seller you're buying them for motor vehicle use. (None of his business in the first place, but those wheels don't have the DOT certification for motor vehicles!)
JW51 Offline OP
Any harm in running 15 inch? The only aftermarket steel wheels I can find in 6 lug are some smoothies from Coker. Wouldn't look bad, but they are 15.
"New tires are high on my list. Whitewalls. Would also like to find some wheels to get away from the locking ring ones. Hard to find 6 lug."
Do your 3100 wheels have a locking ring? I thought that only GMC trucks had those?
There is no harm using 15" wheels, they were one of the wheel options for 3100s in 1951.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Leo Offline
That's a nice truck, way better than any I've seen, considering it's straight from the barn.
I'm not sure how tall a tire you can get for the 15" rims, tall tires may not be as good for cornering but sure help your top end. One common complaint is that the truck won't go past 50 or 55 mph.
Probably should move this thread but since it has multiple topics within the thread, I'll leave it here for now and even add a comment or two of my own!!
I have a little different opinion on doing brakes first. I've always thought it would be a shame to spend money on the brake system only to later find out the engine, or some other major item is shot. Then the vehicle sits with all that money spent while digging out more just to get it running. Strictly MY opinion but I like to get them to GO and then WHOA.
However, JW51, if you have a firm plan to keep going after the brake job then by all means go ahead with the brakes.
Not sure if you have Huck or Bendix brakes but most Flaps can still get brake shoes and wheel cylinders. If not in stock they can get them overnight with free shipping. The brake lines are cheap and lengths can usually be matched up so there is a minimum, if any, flaring done. Just don't skimp on brakes!
In the Gallery [stovebolt.com]
More photos [photos.app.goo.gl]
Pictures! [photos.google.com]
Original optional 15" tires were a larger diameter than either of the original 16" tires (as shown in the link I posted above).
1951 31xx brakes were Bendix in front and rear (first Bendix year).
I like Alvin's logic on the brakes. However, before you go for a ride of more than one block, go over the brakes.
Tim
JW51 Offline OP
I'll post any new questions in the right thread.
Appreciate the insights from Achipmunk and tcelderman. My thoughts with the brakes first have to do with my house and garage. Concrete drive that is steep. Want to be able to stop before I put it in the garage and tear into anything else.
Dropped it off at the shop for the brake work today. We'll see what happens.
As for the question about the locking ring wheels --- don't know that they're original, but given the rest of the truck --- can't say that they're not. You guys would know best!
Page 2 of 4 1 2 3 4
