The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
That time of year with some last chances to get together in bunches. Time to check out:
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: the ODSS gathers this week (Sept 22-24) at a yearly ATHS show in Winchester VA.
Since we put up this promo last week, a bunch of new postings of Swap Meets, Cruisin's, and more
in the SIDE LOT.
See what's happening with a Stovebolt Collective near you
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (Unsupervised_aga, 1 invisible), 83 guests, and 3 robots.
Forums60
Topics129,094
Posts1,046,667
Members46,191
Most Online1,229
Jan 21st, 2020
#984553 Fri Nov 08 2013 04:49 PM
stiffy Offline OP
i was on here a while back inquiring about an engine for a '37 chevy fire truck. i found a good engine, although much newer than the '37. it has an oil pump rather than the spash oiler. it has been installed, with some minor modifications, such as the motor mounts, and the installation of an electric fan due to the extra length of the motor, which didn't allow enough clearance. I'll add some pictures when I finally get it all done. i would like to know what type of addatives to use with the unleaded/ethanol gas. also, since the vehicle won't be driven for the winter, what kind of stabilizer i need. thanks from a rank amature.
stiffy #984557 Fri Nov 08 2013 04:58 PM
Just drain the gas. Just dumping stabilizer in the tank will not treat the fuel in the lines or carb.. it can still gum up. Drain it into a gas can and use it for your lawn mowers/chainsaws etc.
I run my 1942 Ford GPW with no additives and 10% ethanol (regular pump gas) with no issues. It's an L head and still has the original cast iron valve seats.
The general consensus is that the motors are not driven hard enough/enough miles to justify hardened seats OR additives.
stiffy #984605 Fri Nov 08 2013 08:29 PM
I don't know what kind of unleaded is sold in NY but most of us are buying E10 or 10% ethonol and it goes to pot in short order in my experience. I try to not let anything set for over a month w/o running it until good and hot and over the winter I use Sta-Bil and find it works well. No need to worry about your 2 cycle gas if it's stored with the oil mixed. As for the gas cans (I must have 10) I try to empty them in cars I drive by Nov and use Sta-Bil in the ones I must carry over. BTW, this morning our gas price was 2.78.9 for 87 octane. Think I may have to fill all those cans again.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
stiffy #984656 Sat Nov 09 2013 12:10 AM
Stabil works fine for me, too. Just draining the tank, doesn't remove stale fuel from lines and carb, can also get 5 or 10 gallons of aircraft fuel(100LL or Mogas) that has no alky, fill up with that and run for a short while before putting away for winter.
stiffy #984847 Sat Nov 09 2013 05:30 PM
I've read a few articles recently about winterizing. They actually suggest keeping your tank about 75-90% full. The reason being, It keeps condensation from entering your tank.
I've heard the age old myth that ethanol draws moisture. The fact is that moisture BONDS to ethanol molecules. So, the less moisture and condensation that is allowed in the tank, the less chance there is of phase seperation, and moisture related problems.
Another benefit is that there is rust and oxidation inhibitors in fuel. An old 'bolt has a steel fuel tank. So what happens to bare steel? It rusts. An empty tank left open to condesation is just an invitation to rust.
http://www.oregon.gov/osmb/pages/news/e10winterizing.aspx
BTW- The main ingredient in Stabil IS Alchohol.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
