The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 members (ASU, cmayna, BC59, Dan Bowles, fonz8261, 1 invisible), 296 guests, and 3 robots.
Forums47
Topics117,852
Posts943,075
Members43,059
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1954 Jagrolet
#968825 Mon Sep 02 2013 11:12 PM
sfeldma Offline OP
Here's what happens when you glue a '54 3800 to an '88 Jag XJ6 car.
Final Product
We stripped the front and rear axles from the Jag and hauled the carcass to the recyclers. The car was non-running and pretty much trashed.
What's left of Jag XJ6
The I found a '54 frame from a 1/2-ton hydramatic truck from South Dakota. Stripped the stock axles and grafted on the Jag axles.
Jag front end
Jag rear end
Dropped in the 235 from the 3800 and adapted a T5 5-speed from an S-10
235
T5
Pulled the cab and front dog house from the 3800 and installed on 1/2-ton frame:
Old 3800 cab
Found an old '54 short bed and some fenders.
Ugly bed
Get high school kid to clean inside. Wanted to keep outside original, but we stripped inside and installed peel-n-stick fake dynomat and redid seat.
Safety third
Rattle can resto
Putting it all together.
Rebuilt 235: '54 block with '56 848 head
Getting there
New pine bed but kept old metal str... look right with shiny stainless strips.
Before washing with CLR
After washing with CLR
Truck is running great and drives nice. I need to install power steering pump because the Jag rack doesn't like being used manually. It steers, but I'm basically pushing fluid from one side to the other when I turn. It's got disc brakes all around and I'm thinking about upgrading to a power booster. I also want to lower the rear about 2" by raising the top of the shock towers. I was surprised there is enough room to do that with the floor in place in it's original position, but I measured and I've got 2" to play with. I might splurge for airride shocks in the rear so I can drop it really low if I want to.
I'd like to find a '54 bed in the same green as the cab. The orange bed is solid, but looks kind of weird. No plans to paint truck. I like the old look and it cleaned up nicely using CLR and green scotch brite pad.
1954 Chevy 3100
"Jagrolet
More pix on my website
1953 f100 w/ v8
1953 f250 w/ v8
Re: 1954 Jagrolet
sfeldma #968826 Mon Sep 02 2013 11:15 PM
sfeldma Offline OP
All photos of build here:
Build photos of Jag-rolet
1954 Chevy 3100
"Jagrolet
1953 f100 w/ v8
1953 f250 w/ v8
Re: 1954 Jagrolet
sfeldma #968842 Tue Sep 03 2013 12:00 AM
You'd never know by looking that it wasn't totally original. Nice job!
Rich
'47 Loadmaster
Life is like a roll of toilet paper--the closer you get to the end, the faster it goes!
Re: 1954 Jagrolet
sfeldma #968920 Tue Sep 03 2013 09:46 AM
Boltergeist
Hey I like what your doing. Nice work.
Pictures in my Photobucket
52 Chevy Panel
Re: 1954 Jagrolet
sfeldma #969571 Thu Sep 05 2013 08:13 PM
Cool build!
Moderated by  J Lucas
