The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (Alainfrenchie54, Achipmunk, 51sub, coilover, 57 Apache Stock, 2 invisible), 261 guests, and 5 robots.
Forums47
Topics117,647
Posts941,148
Members43,017
Most Online1,229
Jan 21st, 2020
Image Posting Policy
’41 Head Light Wires
#95363 Sat Apr 15 2006 02:58 AM
Kip's41 Offline OP
Anyone out there know how the headlight and parking light wires are routed on a 1941?? I have made up my own harness and was able to find the route from the switch and dimmer out to the terminal block on the left front fender. From the remnants of the old wiring I can see how it is routed from there to the left headlight. But how were the wires run across to the right terminal block, over, along the radiator tank, or under somewhere along the frame cross member??
1941 Chevy Master 3/4-Ton
More pix in the Bolt Bucket
Born to fish, the truck is only a hobby.
Re: ’41 Head Light Wires
#95364 Sat Apr 15 2006 03:26 AM
On my 46 there are two J clips soldered on the radiator tank. http://oehmjr46.tripod.com/id45.html
#95365 Sat Apr 15 2006 05:42 AM
On my truck, I have a "Farmer Fix" for the starboard head and parking light harness.
A piece of copper wire is acting like a hanger. it's wired to the radiator support.
I have a feeling that it was originally clipped on somehow (probably with clippies similar to the harness attachment to the inner fender on the port side).
#95366 Sat Apr 15 2006 05:23 PM
8
On my 41 Kip, there are two somewhat flexible hooks mounted to the radiator top. It seems like this would get hot and roast but so far it has not. How's the horn coming? I have a horn if you need one. Bert
Greater love have no man than this,
That he let his wife drive his truck to the grocery store.
#95367 Sat Apr 15 2006 08:33 PM
Kip's41 Offline OP
Great photos Oehm Jr. Looks like you have some original wiring. On very close inspection looks like my radiator had these clips at one time. Mystery solved, thanks to all !!
Bret: I’ll be in touch about the horn. I have a friend at work who is very good with electrical stuff and I want to see if he can come up with a replacement widget.
#95368 Fri Apr 21 2006 01:33 PM
8
Still have the horn and a 41 steering wheel
Moderated by  Rusty Rod
