Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
17 members (78buckshot, cmayna, 2-Ton, D'Ecosse, AS37, 1Ton_tommy), 165 guests, and 3 robots.
The Zone
Forums65
Topics123,390
Posts998,842
Members47,294
Most Online1,229
Jan 21st, 2020
#943233 Tue May 14 2013 08:20 PM
Sometime ago there was a post here regarding a 6 volt Battery Jump-Starter. I mentioned that I had one and a person you frequents here very often in so many words said I was lying.
At that time I could not find it to take a pic. Well, today I found it tucked away under my work bench.
See the pic...
Link to unit...
That looks very handy.
Does LectricLimited (Battery Butler) still sell either the 6v or the 12v Battery Jump Starter?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
I don't know if they still make the jump-starters or not. The link I gave was on the box.
I only used that thing one time (worked Ok) I installed a optima battery shortly after I got the unit (about 7 years ago) and have had no use for it.
Thanks for sharing the info. I called Lectric Limited, Inc. this a.m. They no longer carry this unit. BUMMER!
