The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (Flatblu4748, Bill Trotter, D B Cooper, Napco Man, 55_2nd_Series, DaveV), 89 guests, and 3 robots.
Forums60
Topics124,660
Posts1,006,226
Members44,993
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 4 1 2 3 4
Re: blow by maybe?
lilrobo #935666 Sun Apr 14 2013 01:18 PM
sounds about normal, so you can figure your gauge at 200 is telling you everything is fine, seeing it get higher suddenly, or run consistently lower tells you things need checking, like water is low or stat went bad .... the old gauges are not scientific grade instruments, they're to show changes from "normal"
Re: blow by maybe?
lilrobo #935746 Sun Apr 14 2013 08:03 PM
lilrobo Offline OP
went driving today and seems like i am smelling the oil smell more than i did befor,, i will check if i added too much oil , i did a oil change and added a bottle of zddp, but i didnt put the full last qt in ,,, so that might be it ????
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
Re: blow by maybe?
lilrobo #935890 Mon Apr 15 2013 12:41 PM
lilrobo Offline OP
just check the oil and its above the full mark ,, so thats the reason i am smelling oil i hope ???
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
Re: blow by maybe?
lilrobo #936707 Thu Apr 18 2013 05:54 PM
Y
A little vapor "smoke" is normal when idling after start up. Oil vapor/mist will be present at temp. The temps you call out don't seem bad to me. Modern cars recycle all that vapor so you never see it. You will also get the hot oil vapor smell coming from the engine compartment, where on modern cars it all gets recycled. If it looks like a coal train in a black and white movie I would be concerned, if it looks like a hot cup of Jo on a cool day I would call it normal.
A long test drive is not a bad idea because you can listen to it over time and observe when it has been running at temp for awhile. Plus any excuse for a drive works for me.
No strange noises or loss of power?
You know you only truly love your old truck or tractor after the point at which you are ready to push it off a cliff, but you suck it up, get it running, and get it back into service...... The 3rd time
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
Re: blow by maybe?
lilrobo #936911 Fri Apr 19 2013 04:27 PM
lilrobo Offline OP
I had a guy looking at it and was interested in buying it until he smelled oil i told him it was coming from the road tube,, so i dont know what to do now, ,i am going to change to rotella with out the zddp and take it out on the interstate and give it a go, , anything else i can do?
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
Re: blow by maybe?
lilrobo #936921 Fri Apr 19 2013 05:00 PM
How many miles on it total since the rebuild?
How far/long is it's average trip?
How far is a 'drive'?
Have you considered switching to PCV instead of down draft?
Give me ambiguity
or give me something else
Re: blow by maybe?
lilrobo #936947 Fri Apr 19 2013 06:45 PM
Bubba
Please answer CASO's questions (at least the first 3) before asking for other advice.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: blow by maybe?
lilrobo #936957 Fri Apr 19 2013 07:41 PM
Rotella is one of the stinkier oils. I know because I use it!
1951 1 Ton Completed
Re: blow by maybe?
lilrobo #936975 Fri Apr 19 2013 09:18 PM
lilrobo Offline OP
I say about 500 on rebuild,,,
The other night was the lonest it was 30 miles each way
Normal is about 15 miles on a fri night and same for sat night
I just putt around i am not a hot rodder lol
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
Re: blow by maybe?
lilrobo #936993 Fri Apr 19 2013 10:04 PM
Bubba
A 60 mile trip should be enough to have the road draft tube clear gases from the engine.
Tim
Page 2 of 4 1 2 3 4
Moderated by  Woogeroo
