The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (Gray_Ghost, buoymaker, 50GMC253, Eureka Jim, greenie-reddy, 2 invisible), 116 guests, and 3 robots.
Forums60
Topics126,008
Posts1,018,306
Members45,402
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Best replacement carb
Dogface #920352 Sat Feb 16 2013 06:31 PM
I wonder why the guy would want to sell his double setup if it worked well for him.
1951 1 Ton Completed
Dogface #920379 Sat Feb 16 2013 09:09 PM
I need to see a video of that leaking, I can't think of any brass rod that would cause leakage of that sort. OH, and some of the reasons someone might want to sell the dual carb setup is it won't fit with fenton headers, (I had to get a FENTON intake, the edelbrock wouldn't fit), maybe they got a wayne 12 port and it won't fit that either, he went with a V8, had clearance issues with the fender braces, simply changed his mind. There doesn't need to be an ulterior motive, no one mentioned whether it worked well for the fella or not, as a matter of fact, it didn't say whether it has even been installed on an engine period
Dogface #920435 Sun Feb 17 2013 08:49 AM
A progressive two barrel will not work on its own, you need two of them. One is just to small for the 235. This is why they work so good in dual setups.
Unless the the carb has a direct hole in the casting letting fuel out, it can be rebuilt and made to run pretty decent. Any fuel running down the sides or out the shafts is from overflow or leaking gaskets.
First thing to do is add a small fuel filter right at the carb inlet. Then open the top and remove any trash that you see. Look under the needle valve and flush the area. Check the float for leaks and be sure it floats, replace it if in doubt.
Find another carb mechanic.
Joe
Dogface #920440 Sun Feb 17 2013 08:57 AM
I agree with joe on all points, especially the part about finding another mechanic. The only thing I could add is you could learn to do this yourself, that way you know exactly what is going on. The rochester is about 1 step above a briggs and stratton in complexity.
Dogface #920441 Sun Feb 17 2013 09:02 AM
Bubba
There is at least one Holley-Weber carburetor (2300 or 5400?) that is a progressive 2-barrel carburetor that is big enough to not have to be used in pairs on 235 engines. Tom Langdon sells at least one type of these progressive 2-barrels ( 32/36 DGEV). Supposedly, these are 300 CFM carburetors. Two of these would be too much, even for a 261.
The Carter-Weber 740 (some call it a Holley-Weber 740 ?) is a much smaller progressive 2-barrel carburetor (used on 1600 cc Pintos, among others) and needs to be used in pairs on 235 engines. Tom Langdon sells these in pairs. Two of these are a little too small for a 261, but should work very well on a 235 (which is what Tom seems to usually recommend them for use on).
I agree with Brokenhead regarding trying to rebuild an original Rochester (unless it is leaking from a a pivot-shaft - that is not a simple parts-replacement rebuilt).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Dogface #920450 Sun Feb 17 2013 09:39 AM
Looking at your beautiful truck so nicely done I'd make every effort to stay with a stock carb. My 53 was flooding really bad, gas everywhere, turned out to be way to much fuel pressure. Picked up an adjustable fuel reg. at Napa and now no flooding in the engine room. These carbs do not like pressure over about 2 lbs tops.
1946 1/2-Ton Chevy [stovebolt.com]
1953 Chevy 3/4-ton Factory Stakebed [stovebolt.com]
JiMerit Boltr#43 #920480 Sun Feb 17 2013 11:15 AM
Dogface Offline OP
Interesting... I'll see if my guy mess. the fuel pressure ...
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
brokenhead #920484 Sun Feb 17 2013 11:22 AM
Dogface Offline OP
First, I'll have my guy test the fuel pressure. The guy I'm thinking of buying the set up from had it installed on a 235 which worked fine but he changed motors to a 261....too small for that. He's a mod here.
I may just do as many have suggested and have this Rochester repaired...Joe Hand has asked me to send it to him...would be nice, in a way, to keep it stock.. Lots of other projects to do in the mean time.
Mark
1949 Chevy 1/2-Ton
Lucielle
Page 2 of 2 1 2
Moderated by  Woogeroo
