The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Thorens, Joe W, Roxxstar, ttoaster, Fox, 1 invisible), 180 guests, and 4 robots.
Forums50
Topics118,898
Posts951,734
Members43,288
Most Online1,229
Jan 21st, 2020
Image Posting Policy
exploding gas tank
#90245 Mon Nov 19 2001 08:30 PM
Sparks Offline OP
Junior Member
Will my gas tank explode? I got a replacement gas tank sender for my '51 Chevy 3100. The resistance coil on the replacement is not enclosed inside a case; it is open and is immersed in the gas. Can sparking occur between contacts on the coil and the float arm as it moves to register the gas level? My truck is still 6V, but will it spark more if I convert to 12V? On the original sender, the resistance coil was completely enclosed inside a pot-metal casting. Is the original, enclosed style still available anywhere?
Re: exploding gas tank
#90246 Mon Nov 19 2001 09:33 PM
I think that if the thing is immersed in gas, it wont make the gas explode. The thing about gas is, if you throw a match into the tank, it wont explode. ( I know, I have tried it dumb kid stuff) DONT DO IT! usually what explodes is the FUMES from the gas. I have never heard of an open case for the resistor coil, but if it works then leave it be. smile
#90247 Tue Nov 20 2001 06:51 AM
Even an empty tank should resist explosion. The mixture is to rich (even empty )for combustion. I used to wonder how they could run those electric fuel pumps inside the tanks and not risk an explosion.
#90248 Tue Nov 20 2001 04:42 PM
A word to the wise...the sender in the gas tank and the dash gauge have to match. For example a 6 volt gas gauge runs on 0-30 ohms while a 12 volt equlivent runs on 30-90 ohms. In other words the sender and the dash gauge must match each other. The best solution when you decide to convert to 12 volts is to use a Runtz on the original 6 volt gauge. A Runtz will allow you to keep the original 6 volt gas gauge and sender. You might also check the new sender you just got to be sure it is compatable with your 6 volt dash gauge. You might end up with one tennis shoe and one cowboy boot...how embarrasing grin grin grin grin
#90249 Tue Nov 20 2001 05:45 PM
Sparks Offline OP
Junior Member
Fifthave, Does that mean that my 6V sender should register 0-30 ohms when cycled from full to empty? Or is it the 6V gauge that registers 0-30 ohms from full to empty? Whats a Runtz (resistor?) anyway? When I was installing my wiring harness, I found this thing (two electrical leads, 1/4" square x 2" long) attached to the back of my gage cluster. Is it a Runtz?
Moderated by  Rusty Rod
