The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
26 members (50wudy, 55 SHAKER, 51sub, 55_2nd_Series, 66flea, 2 invisible), 111 guests, and 3 robots.
Forums47
Topics117,793
Posts942,571
Members43,043
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Ignition Coil problems
#89427 Sun May 22 2005 06:43 PM
Dutch52 Offline OP
Yesterday I was driving the truck all day when in the afternoon (after stopping at a store for 10 minutes) the truck died.I do use a disconect switch all the time if I am not in the truck. I opened the hood and saw oil coming out of the (new) coil, I let it cool down and truck started and died again. Why is the(new)coil overheating? Jo
Re: Ignition Coil problems
#89428 Sun May 22 2005 07:14 PM
Do you have a resistor in the ignition?
1957 Chevy Stepside
1993 GMC Sonoma
#89429 Sun May 22 2005 08:09 PM
New coil? What kinda coil?
Buzz'n Half Dozen
#89430 Sun May 22 2005 08:28 PM
Dutch52 Offline OP
The Truck is stock 6 volt. The coil is an Echlin Standard. Truck has run for weeks with no problem. jo
#89431 Sun May 22 2005 08:37 PM
gen is putting out too much voltage? [like bad regulator]
ignition resistor shorted out and is putting full voltage to the coil?
check resistance across the resistor and voltage at the coil
#89432 Mon May 23 2005 12:55 AM
I have never seen a 6V with an ignition resistor. Did you install the coil upside down?
Jason
#89433 Mon May 23 2005 01:24 AM
Dutch52 Offline OP
Jason, I do not have a resistor installed.
The coil is installed with the cables on top as it will not leak that way. jo
#89434 Mon May 23 2005 06:33 PM
Can you measure the resistance between the + and - terminals? Should be near 1.5 ohms. Maybe it has developed a short.
Jason
#89435 Tue May 24 2005 03:12 PM
Your best bet is to replace the DOA coil with an NAPA Echlin IC7. It will have the ballast resistor built in and has proven to be very reliable. It is all I have used for 6 volt projects for the past ten years...Thanks Randy
#89436 Tue May 24 2005 03:13 PM
Page 1 of 2 1 2
Moderated by  Rusty Rod
