The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (HandyAndy, 52Carl, 1953 panel, '37 barn find, carbking, 1 invisible), 231 guests, and 3 robots.
Forums50
Topics119,924
Posts960,459
Members43,517
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Gas guage works
#88330 Sun Nov 18 2001 01:39 AM
Gavin Offline OP
Well I finally fixed the gas guage on my 62. It stopped working one day while out four wheeling in the desert. The other day I ran out of gas about a block from work so that did it. I got the trusty manual and did the checks that it says and all things were pointing to the sender. I removed it and found the metal strip missing a chunk that I guess is in the bottom of the tank. I didnt want to buy a new sender because the money is tight so I cut a length of 16 guage wire and removed the insulation and soldered it to both ends of the sender in place of the metal strip. I hooked up the wires and then moved the float to the top and then slowly down to the bottom and I will be darned. The dang thing works. Saved money and gained knowledge. Cant do that to these new cars. grin
Everybody was born crying, most of us get over it.
Re: Gas guage works
#88331 Tue Nov 20 2001 12:34 PM
Might be a common sender problem - mine was the same. I did like you did, but with a coiled length of MIG wire. Works smoothly now. Easy fix and cheap too.
Moderated by  Rusty Rod
