The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (Powerpigs8, Flatblu4748, 68ironhead, Hotrod Lincoln, JiMerit Boltr#43, Mike B), 266 guests, and 3 robots.
Forums60
Topics123,387
Posts995,755
Members44,653
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Source for Brake Parts
#878573 Tue Aug 28 2012 09:44 PM
Duwop Offline OP
I need 14x2.5 shoes and wheel cydrs, who is a good source for these?
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800
More pix on Flickr
Re: Source for Brake Parts
Duwop #878585 Tue Aug 28 2012 10:04 PM
Wheel cylinders can be found at NAPA and Chevs of the 40's.
I have been looking for shoes with no luck. I am going to get them re-lined at my local brake place.
Redlegs48 #878637 Wed Aug 29 2012 12:50 AM
Previous Post
I can't recommend the Dorman wheel cylinders after trying to install them. The mounting bolt holes are misplaced and the bolts can't be tightened up against the backing plate.
The other stuff fit perfectly.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
OlBlue #878654 Wed Aug 29 2012 03:33 AM
Napa brake shoes UP-299R are 14x2.5 bendix style brake shoes. They fit perfect on my '53 except I had to drill the hole for the park brake arm mounting bolt.
1953 1 ton panel
PootersPanel #878718 Wed Aug 29 2012 10:38 AM
Duwop Offline OP
Thanks for your help. The Napa part no# for the rear wheel cyd is #18010 its 1"1/4 bore. Parts are coming in a few days.
1957 Chevy 3800
More pix on Flickr
Duwop #878720 Wed Aug 29 2012 10:41 AM
Duwop Offline OP
Napa can get your shoes Redlegs48 if they are the same as mine the part # is up-299r. Thanx PootersPanel
1957 Chevy 3800
More pix on Flickr
Duwop #1152879 Tue Mar 01 2016 09:00 PM
This was very helpful! Thanks for the item numbers. I called my local Napa and they had the cylinders and shoes. Saved me from pulling some hair from my head!!
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
Duwop #1153244 Thu Mar 03 2016 06:18 PM
I placed my order from NAPA. Shoes look to be fine, cylinders don't fit. The screws just don't line up. So I found AUTOZONE has similar ones, DURALAST item number 33048 and ordered them from there. Fingers crossed those will work. Otherwise I suppose I can just rebuild them.
Duwop #1153249 Thu Mar 03 2016 06:29 PM
Did you check Rockauto.com?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Duwop #1153259 Thu Mar 03 2016 07:15 PM
Yes, I bought all my items for the front from Rockauto but they don't have the items for the rear.
Page 1 of 2 1 2
Moderated by  Grigg
