The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (Joe W, BC59, Hotrod Lincoln, harv, 63 C-10 Carolina Fleetside, Greg Brown), 285 guests, and 3 robots.
Forums47
Topics117,832
Posts942,914
Members43,050
Most Online1,229
Jan 21st, 2020
Image Posting Policy
year of 6 volt to 12 volt conversion from factory?
#877815 Sun Aug 26 2012 12:28 PM
I know the AD trucks were built using 6 volt systems. But I was curious what year did Chevrolet (or other companies either)start to use 12 volt electrical systems in their trucks as built from the factory? Brian
Re: year of 6 volt to 12 volt conversion from factory?
Brian_Ostner #877824 Sun Aug 26 2012 01:27 PM
Boltergeist
The 2nd.-generation 1955 Chevy trucks made the switch to 12 volts. I'm not sure when GMC swapped over, nor whether they kept the positive ground system for awhile after the switch to 12V. I don't think so. By 1957, all the major auto manufacturers had standardized electrical systems at 12V negative ground at the urging of aftermarket electrical accessory manufacturers. Freightliner big trucks hung onto the 12V + ground system until the mid-1960's.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Hotrod Lincoln #877855 Sun Aug 26 2012 03:56 PM
ace skiver
GMC went through all of 1955 with standard 6v positive ground on small trucks. Large GMC trucks switched to standard 12v (neg ground) in late 1955 (Blue Chip GMC).
All GMC trucks were 12v negative ground in 1956.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #878257 Mon Aug 27 2012 09:40 PM
As an interesting aside, I have a set of GM instructions for converting a truck to 12 volts. I think it was published for the year 1949. It was mainly to provide better starting in the winter.
1951 1 Ton Completed
truckernix #883107 Sun Sep 16 2012 08:29 PM
I have a first series '55 3100 and it came with a 235 six and twelve volt system. My buddy has a '54 (they look identical) and his has a 6 volt system. A close friend has a '56 Fiord and it is 12 volt. I know the '55 Fords were 6 volt. So maybe 1956 was the changeover for some and others did it in '55?
Normbc9
123456789101112 #883113 Sun Sep 16 2012 08:47 PM
The 55 1st series truck would have been 6 volt. The 55 2nd series truck would have been 12 volt.
Don't know about the Fords.
Roy Rodgers #883225 Mon Sep 17 2012 08:56 AM
Global Mod
Agreed. If your 55.1 had 12v when you bought it someone ahead of you converted it.
Tiny #883270 Mon Sep 17 2012 02:04 PM
Exception to the rule: 1955 GMCs with 6 cylinder were 6V in both series.
My TRUCKS website
Cletis #883363 Mon Sep 17 2012 09:05 PM
ace skiver
Big 1955 Blue Chip GMC trucks, 550-650 series "big trucks" were standard 12v. It is interesting to note that models 100-410 GMC V-8s were 12v, with some of the larger models having optional two/dual 12-v batteries.
Tim
tclederman #883587 Tue Sep 18 2012 11:45 PM
Boltergeist
Ford switched to 12V in 1956, but it was a positive ground system. All auto manufacturers standardized at 12V negative ground in 57, but a few oddball big trucks like Freightliner kept the positive ground system through the mid-1960's. Nash and Packard, and possibly Studebaker also ran 12V positive ground systems for a short time prior to 1957. 6 volt MOPAR cars and trucks were positive ground until 55 or so.
Moderated by  Rusty Rod
