The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (DES57, 66flea, 55 SHAKER, Cosmo, AD8, 1 invisible), 105 guests, and 3 robots.
Forums50
Topics119,562
Posts957,352
Members43,427
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
6 volt vs 12 volt headlight switch
#86671 Fri Nov 16 2001 10:03 PM
Lumpy Offline OP
Junior Member
Do I need to replace my original 1953 headlight switch now that I have converted to a 12 volt system? I have seen headlight switch advertised for my 53 as 6 volt or 12 volt. What is the difference?
The truth will set all men free.
Re: 6 volt vs 12 volt headlight switch
#86672 Fri Nov 16 2001 10:35 PM
They have differences in the amperage rating. You should be able to get one at a good NAPA parts store.
#86673 Fri Nov 16 2001 10:41 PM
I believe (and I'm sure I'll be corrected if I'm wrong!) the 6V systems use higher amperage. 6V systems use heavier guage wire, too.
So the 6V part should work for either!
-Boyo
[ 11-16-2001: Message edited by: boyoconnor ]
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#86674 Fri Nov 16 2001 10:45 PM
If your 6 volt lamps were about 40 watts, then the 12 volt bulbs at 40 watts draw 1/2 the current of the 6 volt.Your swich if in good shape is fine.
#86675 Sat Nov 17 2001 05:08 AM
Boyo and Tony are right. The higher the voltage, the less current, meaning your 6 volt switch will last far longer than a 12 volt. smile
Fred
52 3600
69 C-10
#86676 Sat Nov 17 2001 07:38 AM
I cant decide if the noise in my head is 6V or 12V
I no it's no vacuum cause it don't stop when I'm on the gas......
AND I hear the faint call of Slim Whitman beckon'n for me to dye my sideburns annnnnn...
Oh NURSE!
#86677 Sat Nov 17 2001 05:27 PM
ace skiver
Hey, J.H.,
I know what you mean. eek
Tim
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
#86678 Sun Nov 18 2001 07:48 AM
J. H., I don't?? :confused:
I've been running my 54 with 12 volt for 3 years now, no problems. I think it's just a sales gimmick, they are probably the same switch, diff labels. Why would they have two if one would work for both? :rolleyes:
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#86679 Sun Nov 18 2001 01:08 PM
Jim, me and Joy keep hearing talking also. Happenened at night when all is quiet.Yesterday she found one of those talking picture frames was the source.We still hear talking in our heads even after removing the battery from the talking frame.
#86680 Sun Nov 18 2001 04:47 PM
Maybe the difference between the 6 and 12 volt is in the rheostat for dimming the gauge lights.
Jason
Page 1 of 2 1 2
Moderated by  Rusty Rod
