We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,519
Posts1,032,226
Members45,797
Most Online1,229 Jan 21st, 2020
 '59 Apache fleetside 6volt or 12volt
OP
I'm new to Stovebolt and just picked up a '59 283 4spd, it has a generator hooked up and a 12V voltage regulator so trying to determine whether it's running on 6v or 12v. The wiring appears to be original. What is best way to determine. Thanks.
 Re: '59 Apache fleetside 6volt or 12volt
Chilton's says 12V and negative ground.
all Chevs were 12V after 55 .... check a factory manual, for '59 you need the '55 shop manual and the '59 supplement, as well as the '59 operators manual Bill
OP
thanks for the info..the manual ref will help tons.
