The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
E V E N T Highlight
Southern
"STOVEBOLT"
Jamboree 2022
July 8 and 9
Lebanon TN
The Southern Bolters are planning their area get together in
conjunction with the
Southeast Truck Nationals at Cedars of Lebanon State Park (TN)
Check out the details, with new info on the Southern Bolters forum.
Plenty of other events in the Side Lot
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (Hotrod Lincoln, JW51, bowtietim, hippydave, 1 invisible), 71 guests, and 3 robots.
Forums59
Topics127,967
Posts1,036,049
Members45,902
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 5 1 2 3 4 5
vwlfan #846537 Wed Apr 25 2012 05:55 PM
vwlfan, it looks like a dimmer switch on the passenger side under the heater. Just what it that for?
Thanks for the photos. Nice.
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
V
That is a dimmer switch which was mounted in the passenger side floor which allows the passenger in the fire truck to operate the siren. - Bob
vwlfan #846590 Wed Apr 25 2012 10:44 PM
Originally Posted by vwlfan
[quote=tclederman]
My 54/55 GMC COE dash looks like vwlfan's, including the knobs.
The choke cable on my COE does not have the original knob. None of the available choke cables (with correct knob) on the market were long enough in length to be used for a COE application. I did buy the correct choke knob but I have not yet attempted to remove the third party knob and update it with the correct knob.
Originally Posted by GMCpanel
One question - why are your gauge panels black?
The gauge panels in my COE are the original panels and are unrestored. So at least the non-deluxe trucks had black gauge panels. I bought an extra set of 54/55 gauge panels for a spare and they are black also:
1954/1955 GMC Spare Gauge Panels
That's one of the best-preserved interiors I've ever seen.
You might enjoy some of these photos which are from my 53 GMC Fire Truck. The interior is one of the cleanest original and unrestored interiors I have seen.
1953 GMC Unrestored Interior
This is a photo of the area under the gas tank at the time I removed the tank. I know this area looks repainted but this is the original non-faded paint.
1953 GMC Paint Under Gas Tank
Bob [/quote]
Interesting. Your headlight knobs looks like the correct style, but it's black instead of ivory. My panel had the ivory knob, but UV radiation completely destroyed it. The wiper knob is also different from Chevy, but it also rarely survives in the sun. IMHO, the Chevy headlight and wiper knobs look better, just paint them to match. Same with the throttle and choke knobs. The parking brake, window crank, turn signal, radio and heater knobs are all the same as Chevy, but in ivory instead of black.
With the two-tone seats, I'm pretty sure your truck has the DeLuxe interior. Does it have the driver-side armrest and passenger-side interior visor?
I've just looked up some pics of my COE, it has the black gauge panels, too. My 1-ton panel, which also has the two-tone brown interior, has dark brown gauge panels. WTF? That makes absolutely no sense.
1954 GMC De Luxe COE
V
Quote
There is no driver side armrest or passenger side visor on my COE.
vwlfan #846821 Thu Apr 26 2012 04:20 PM
Now I'm really scratching my head.
Im reviving this thread because my urethane adhered step pads are un-adhering. The adhesive sticks to the metal underneath just fine but doesnt stick well to the pad itself.
Does anyone have a better adhesive product recommendation?
Thank you
John Drabik
1949 2 ton GMC COE
V
John,
Like you I could not find an adhesive that worked well with the repro pads I got from JC. The pads are just too "oily", almost like they have a light silicone covering.
Since I only use my truck for shows and limited pleasure driving I used industrial hook and loop to attach the pads. I take the pads off when I am intransit and then simply attach them to the hook and loop on the steps when I get where I am going. - Bob
... The pads are just too "oily", almost like they have a light silicone covering....
many modern rubber products are silicone, holds up better than older carbon rubber formulations .... to glue it you might try Goop or E6000, which is used in arts and crafts work for glass and other hard to glue things
Ayup, they have that silicony, slimy feel to them. Maybe try some black RTV silicon (bluegoo) and see if it adheres.
Failing that, I will try a plastic adhesion assister that comes in a spray bomb made by SEM. And than try to find something else.
Too bad the adhesive issue keeps these pads from being a good product.
John & Bob,
Thanks for posting this information.
I did a lot of searching yesterday for an adhesive that will work between silicone rubber and various other materials (such as unpainted or primed metal/steel). There are some medical adhesives but they are expensive and they are quite specific regarding the type of silicone "rubber" and the type of other surface.
It would be nice to hear from someone who has successfully attached these "rubber" pads to the metal base plates, rather than relying on speculation on what might work. However, speculation and trial-and-error might be the only way of finding a solution (and hoping that the rubber pads do not get destroyed during the experimentation).
This morning, I sent a query to Jim Carter. I'll post his response.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Moderated by  69Cuda, Grigg
