The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (Tommy, Jimmie D, Dusty, joe apple), 236 guests, and 3 robots.
Forums47
Topics117,839
Posts942,973
Members43,058
Most Online1,229
Jan 21st, 2020
Image Posting Policy
What does "LMB" indicate on a serial (vin)# ?
#848846 Fri May 04 2012 03:52 PM
hi
Looking at a 53 chevy project truck to buy. The certificate of title has LMB------ and immediately thereafter is typed the serial (vin)#.
I dont understand what the LMB------- is there for. Is that a prefix for a frame number or an engine number? any help appreciated. thanks for your time.
jerry whitfield in North Carolina or 336-765-8312
my direct email, please, is wwhitfield@triad.rr.com
Re: What does "LMB" indicate on a serial (vin)# ?
jerry whitfield #848850 Fri May 04 2012 03:59 PM
Have you asked the North Carolina DMV?
Tom R #848878 Fri May 04 2012 06:17 PM
Most likely the truck was titled by engine number.
My TRUCKS website
Cletis #848905 Fri May 04 2012 08:34 PM
I was thinking what Cletis said. There is a flat place on the block behind the dist. Clean it off & check the numbers on it. If they match the title you are in good shape. If the title doesn't match any numbers on the truck you better not buy it. Let thev owner straighten it out. It can be a hastle.
1956 Chevy 1/2-Ton Pickup
Wrenchbender Ret. #848931 Fri May 04 2012 10:58 PM
Wrenchbender is right about matching numbers. If the paperwork isn't perfect, you're in trouble. And if the engine has been changed, you may have to pay to get a "bond." One more way to discourage the old car hobby.
A day without sunshine is like, well, ..... dark!
1940 Chevy 1/2 ton pickup "KC"
http://s1237.photobucket.com/albums/ff466/40casey/
40casey #848951 Sat May 05 2012 01:09 AM
ace skiver
jerry,
Since you have been instructed to check for the engine serial number, you might as well check for the truck serial number. It is on a plate mounted on the driver's side door opening, between the hinges.
That code was also sometimes used for the Title/Registration.
The LMB prefix does not match 1953 car or truck codes.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #848962 Sat May 05 2012 02:34 AM
My Chevy Inline 6 Engines 1929-1989 shows no listing for LMB.
My TRUCKS website
Cletis #849077 Sat May 05 2012 05:33 PM
Perhaps LMB is the initials of a rebuilder. Do the stamped numbers and letters match on the engine/door tag? Often the stamps do not match in size or font which is a kind of giveaway that someone has tampered with it.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #849118 Sat May 05 2012 09:40 PM
Maybe someone got twitchy fingers and meant to type "LBM" which are legit 53' letters for a 216 truck motor?
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
Moderated by  Woogeroo
