The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (DennisM, EchoBravoSierra, Greg_H, JimboTX, Hotrod Lincoln, 1 invisible), 93 guests, and 3 robots.
Forums60
Topics126,046
Posts1,018,695
Members45,413
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Leaky 350 transmission
#846809 Thu Apr 26 2012 03:36 PM
50jimmy Offline OP
When I let the truck sit a few days, I get a big puddle of ATF underneath. This is actually the second transmission I have had in the truck. Same problem.I have had the transmission out of it several times, quite frankly I would like to fix it once and for all. Is there something I am doing to cause this? Is there a common cure?
Re: Leaky 350 transmission
50jimmy #846814 Thu Apr 26 2012 03:45 PM
That's a pretty common problem with the TH 350. The torque converter is draining back into the case, and raising the fluid level above the centerline of the driveshaft yoke. There's a tiny hole in the plug in the end of the yoke just ahead of the universal joint to prevent air pressure buildup as the yoke slides in and out. Fluid will leak out of the hole if the level gets too high. The simple fix is to pull the yoke off the U joint and weld up the hole. If you want to do it "right", drop the valve body off the transmission and find out why the converter anti-drainback valve isn't sealing. That's a BIG job with the transmission in the vehicle!
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
Hotrod Lincoln #846817 Thu Apr 26 2012 03:56 PM
Thanks Hotrod L. I have the same problem and appreciate the info.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
hankrags #846856 Thu Apr 26 2012 07:06 PM
50jimmy Offline OP
That is awesome info. I'm for the simple fix.
Moderated by  SWEET
