The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Getting back to business
First round of holidays is about over. A few weeks before the next ones. For some of us...
Winter is Coming
Time to think about wintering your Bolt.
(continued)
A good Tech Tip
WINTERIZING YOUR TRUCK
including a link back to the Forums for some new thoughts.
Searching the Site
Old Truck Calendars
In the works
2023 Stovebolt Calendars
Check for details!
8 members (3800GUY, coilover, 2-Ton, Justhorsenround, Gray_Ghost, 2 invisible), 189 guests, and 3 robots.
Forums60
Topics127,669
Posts1,046,519
Members46,401
Most Online1,229
Jan 21st, 2020
#845217 Fri Apr 20 2012 12:01 PM
It seems I heard that a 216 bell housing won't work on a 235. Just wondering if anyone can tell me if this is correct or not. A friend of mine is going to replace the 216 in his '49 1 ton with a 235 and I told him I thought he needed to change the bell housing, too.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
pablos49 #845226 Fri Apr 20 2012 12:23 PM
The clutch-housings interchange on 216s, 235s, and 261s.
However, if you have a 1953 or earlier truck, you want to use the 1953 and earlier truck clutch housing (rear motor mounts are different). 1954 and later trucks use the later-style truck clutch housing.
Other people might know what year car and truck clutch housings interchange.
You should also use a 6v or 12v flywheel that matches your electrical system (that matches your starter 6v or 12v). Then, choose a clutch assembly that matches the year/clutch-size of the flywheel. Buy the clutch-assembly parts together because there are different sizes (lengths) of throwout bearings. A pilot bushing/bearing usually comes in the assembly-kit - use it.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #845633 Sun Apr 22 2012 05:56 AM
1954 up,the bellhousing was different at the mounts.
Tim
"A house is built with boards and beams,a home is built with love and dreams"
Look deep before you leep !!!
"Everything is Everything"
"If I say a mouse can pull a house,Hitch him up"
My 1951 3100 Chevrolet
My 1951 Chevrolet Suburban Carryall
Moderated by  SWEET
