The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy Birthday U S A !
Celebrating
Life, Liberty
and the
Persuit of Happiness
Happy Birthday
A M E R I C A
July 4 - 246 years
Stories, Pictures, Thoughts
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (MikeE, LexAdmn, Bruce36 1.5, KEVINSKI, Phak1, D B Cooper), 76 guests, and 2 robots.
Forums59
Topics128,080
Posts1,037,102
Members45,928
Most Online1,229
Jan 21st, 2020
#842047 Sun Apr 08 2012 12:02 AM
How does the bell housing unbolt from the block on a 235? Already found the top two bolts but I'm not seeing any others. Just trying remove the small stuff before I scrap the rest.
Hi Slick Willy, to remove the bellhousing you have to remove the pressure plate, clutch and flywheel. Then you have access to two more mounting bolts.
One question for you, what year 235? Do you wanna sell the inspection cover and plate?
not sure what year 235, tell me where to look for the numbers and I'll post the info.
Personal buying and selling should take place in Private Messages and/or in email (check each other's Profiles).
There is a code pressed into the block, just to the rear of where the distributor enters the block. Post that code and people should be able to tell you more about the engine.
Here are locations for a variety of codes that can usually be used to ID an engine.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
There are 4 bolts under the flywheel.
My TRUCKS website
Moderated by  Woogeroo
