The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (Dave Seaver, 52Carl, DennisM, farmall100, Hugh63c10, C10 - C90 Bill, 1 invisible), 299 guests, and 3 spiders.
Forums47
Topics115,010
Posts912,533
Members42,077
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 3 1 2 3
Re: Highway speed [Re: LONGBOX55] #834793
Tue Mar 13 2012 04:03 AM
Achipmunk  Offline
Boiling Springs, S. C. 29316
Well, I don't know where it came from but a fellow bolter in Mi. sent me a pumpkin that is 3.90.... .he says it came out of a 56 or 57 pickup. I do not know but I did look at the ring gears ect when I put a new pinion seal in it.
....I guess I've been told wrong but I've always "heard" there were 3.90's in a lot of the pickups and that it was the later years like the 60's that had even a higher gear???
I'm not claiming or dis-claiming anything here. Just adding to the confusion!!!
Pictures in my Photobucket
52 Chevy Panel
Re: Highway speed [Re: Achipmunk] #834801
Tue Mar 13 2012 04:18 AM
LONGBOX55  Offline
DANVILLE IL
1/2 tons from '54-'62 had a 3.90 gear as standard equipment.
Bill Burmeister
Re: Highway speed [Re: LONGBOX55] #835390
Thu Mar 15 2012 03:59 AM
aggie jon  Offline
Temple Texas USA
I would add for the "doubting thomas" that unless you have a need for a higher gearset, or the rear end is coming from a known, unmolested truck, take the rear cover off, count the teeth on the ring and pinion, just to make sure. I know I bought mine w/o opening it up, and got lucky. My advice if I were ever buying another one, I'd take the 5 minutes to pop the cover off and count the gears.
Re: Highway speed [Re: aggie jon] #835428
Thu Mar 15 2012 08:13 AM
GMCpanel  Offline
Springfield, MO
As I stated above, they should be marked on the edge of the ring gear. Or, if the transmission is out or it's in neutral, just rotate one tire and count the driveshaft revolutions.
1954 GMC De Luxe COE
Re: Highway speed [Re: GMCpanel] #835443
Thu Mar 15 2012 12:25 PM
Whitedog  Offline
IL
Aggie Jon- on a 58, there is no cover to take off. You would have to pull the entire center section.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Re: Highway speed [Re: Whitedog] #835479
Thu Mar 15 2012 03:09 PM
aggie jon  Offline
Temple Texas USA
10-4.
Re: Highway speed [Re: Whitedog] #835484
Thu Mar 15 2012 04:05 PM
Ghostrider  Offline
Binghamton, NY
Are you talking about an Eaton HO72/HO52?
I've never seen one that didn't have a removable rear cover.
Re: Highway speed [Re: Whitedog] #835517
Thu Mar 15 2012 05:38 PM
Ghostrider  Offline
Binghamton, NY
Interesting. I've pulled several center sections from these axles clear up to '72 and pulled the rear cover off every one of them to confirm the gear ratio.
Re: Highway speed [Re: Ghostrider] #840759
Tue Apr 03 2012 01:52 AM
48truck  Offline
Ca
New here,
Was just looking at the talk, I have a 48 3804 9 ft., live in southern Ca. and just had the rear redone out of a 78 3500, that the shop shortened and got some new axels made to fit the wheel base. Not sure of the blah blah to 1 ratio but I can travel at freeway speeds. The 235 with dual YF carbs gets me along just great.
Re: Highway speed [Re: 48truck] #840771
Tue Apr 03 2012 02:35 AM
kb3csw  Offline
Pocomoke City, MD
Had a 48 1 ton it would go along at 55 with 18" tires. The noise didn't bother me at the time. No idea what the rpm was.
Page 2 of 3 1 2 3
Moderated by  Grigg
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
