The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Getting back to business
First round of holidays is about over. A few weeks before the next ones. For some of us...
Winter is Coming
Time to think about wintering your Bolt.
(continued)
A good Tech Tip
WINTERIZING YOUR TRUCK
including a link back to the Forums for some new thoughts.
Searching the Site
Old Truck Calendars
In the works
2023 Stovebolt Calendars
Check for details!
10 members (Lightholder's Dad, JW51, JoeDude, FAST55, 55shaker, KEVINSKI), 216 guests, and 3 robots.
Forums60
Topics127,667
Posts1,046,513
Members46,401
Most Online1,229
Jan 21st, 2020
#831739 Sat Mar 03 2012 03:54 AM
Will a fresh air heater from a '53 work in a '54? Thanks.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
pablos49 #831759 Sat Mar 03 2012 04:50 AM
Yes it will. Hope you got the cable with it.
My TRUCKS website
pablos49 #831760 Sat Mar 03 2012 04:50 AM
OLTrucks
Unregistered
Yes, same heater, The "Air Flow" heaters came out in 1953 and was the same (except the control knob)till 1955 1st
Mike
Cletis #831793 Sat Mar 03 2012 01:29 PM
Thanks for the info. If you're meaning the defroster cable. no, I didn't get that with it. There's a wrecking yard around here that has several AD trucks in it. I might get lucky nd find one there. I did once before.
pablos49 #831802 Sat Mar 03 2012 02:16 PM
On a 53-55 Advance-Design truck outside-air "De Luxe" heater (AirFlow, Fresh-Air), there is no defroster cable (as was used on the earlier style, similar "De Luxe" heater).
The cable in 53-55 is used to open and close an interior-air/exterior-air door on the right-front face of the heater (to regulate between blowing/heating all outside-air to all inside-air).
The 53-55 defroster-lever is hand-controlled (or, maybe, foot-controlled) using the lever on the left front of the heater unit (as used on the recirculating heater).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Moderated by  Justhorsenround
