The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (Johnny N, joe apple, JoeR, baldeagle, Gravelroad46, 1 invisible), 147 guests, and 3 robots.
Forums60
Topics124,697
Posts1,006,493
Members45,007
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: G M C in my 53 ?
#83128 Fri Sep 21 2007 05:04 AM
Thanks for all the advice Guys,
The other thing I didnt mention is that I am planning on useing a T-5 and I dont know how this will work out. I do have two other power plant options one is a non running 235 looks to be a good builder and the other is 1978 250 that runs great the downsides to it are I would really like to keep my foot starter and it has the intergrated head but on the upside it is in great running condition and made to run unleaded.I think I will still get the GMC and keep researching all 3 options. I have plenty of time to make the powerplant deciesion as of my game plan on this project is to get all the body rot repaired first. Thanks again Aaron
#83129 Fri Sep 21 2007 07:25 AM
The gmc will run plenty fine on no lead gasoline. I put over 60,000 miles on one with no lead. When you tear it down it is a good idea to put the hardened seats in.
#83130 Mon Sep 24 2007 04:14 AM
bigbadswingdaddy, the water pump from a 216 will bolt right on a GMC engine, I have done it several times. Aricheson, see if yo can find a core support from a GMC, the radiator will be positioned right. Front motor mounts will be a bit forward of the Chevy ones, I used F**d stock length spring shackles as spacers, they are just the right length. Everything else is a bolt it.
#83131 Mon Sep 24 2007 06:33 AM
chevman, thanks for the correction. I had no idea.
#83132 Mon Sep 24 2007 01:21 PM
chevman32,the late 1930's 216 pumps are probably interchangable with GMC,but for sure not the pumps from after that period.I just compared a early 50's 216 pump to a 228-302 GMC pump,bolt pattern spacing is not the same.
I installed a GMC 302 in a 37 Chevy pu,other than moving the radiator foward about an inch and a half by repositioning the radiator side brackets and fabricating a front mount,it's a no brainer swap.The GMC flat stle 11 inch flwheel and diaphram clutch fits inside a AD truck bellhousing with no problems.
Page 2 of 2 1 2
Moderated by  Woogeroo
