The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
19 members (CdnBigBolt, BlackViking60, blueck, dirtball, Donf, bucktruck), 189 guests, and 3 robots.
Forums50
Topics120,904
Posts969,206
Members43,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Brake Line Specs
#830653 Tue Feb 28 2012 07:41 PM
Glen_P Offline OP
Another question from a newbie... I want to change out my old brake lines. I'm looking at a roll of copper-nickle alloy. Can someone tell me what the original brake line OD should be and what the brake line nuts should be?
Thanks again!
Glen
Re: Brake Line Specs
Glen_P #830658 Tue Feb 28 2012 08:00 PM
use steel lines. copper is a no-no
ron
padresag #830666 Tue Feb 28 2012 08:24 PM
Glen_P Offline OP
I agree copper is a no-no. But copper-nickel seems to be quickly replacing steel. (equal strength, easier to work with and doesn't rust). It is often marketed under Cunifer. It is DOT approved.
Glen_P #830695 Tue Feb 28 2012 10:08 PM
Inline Tube will have what you need.
Tony Smith
4-5-6 Chevy Trucks
501 Scott Avenue
Kansas City, KS 66105
913-207-7789
4-5-6chevytrucks@sbcglobal.net
Photos: http://www.flickr.com/photos/4-5-6chevytrucks/sets/
Custom Parts: http://www.flickr.com/photos/4-5-6chevytrucks/sets/72157627022818563/
www.4-5-6chevytrucks.com
4-5-6 Chevy Trucks #830940 Wed Feb 29 2012 04:36 PM
You can buy NiCopp by American Grease Stick (AGS) online here:
Advance Auto Parts
This is the best price I've found and I believe this is made in USA.
I've used a couple of rolls of 1/4" on my '54 2-ton project and have more ready to use on a '56 GMC 1-ton.
It's easy to flare and easier to bend and install than steel.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
OlBlue #830989 Wed Feb 29 2012 06:57 PM
Glen_P Offline OP
Thanks guys!
So I can assume that the lines are indeed 1/4".
Glen
Glen_P #830996 Wed Feb 29 2012 07:12 PM
Size of the brake lines depend on the year, Series, Make, Model and wheel cylinders of your truck. Most common brake line sizes are 1/8", 3/16" & 1/4", along with the corresponding double-flare nuts, which are matched to the wheel cylinder female brake line opening sizes.
Tony Smith
4-5-6 Chevy Trucks
501 Scott Avenue
913-207-7789
Glen_P #830997 Wed Feb 29 2012 07:12 PM
What year/model truck are you working on?
Almost everything before about 1960 was 1/4" lines. After that you start to see some 3/16" appear and with the advent of disk brakes, lots of 3/16" was used with special sized nuts on the master cylinder.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
OlBlue #831000 Wed Feb 29 2012 07:18 PM
Glen_P Offline OP
It's a 1962 C10.
Glen_P #832296 Mon Mar 05 2012 04:44 AM
@OlBlue, That's a real good tip on the copper/nickle line at Advance Auto Parts! Thanks!
Page 1 of 2 1 2
Moderated by  Hambone
